Lincoln-Anyone know the Model # and Specs?
发表于 2021-8-31 22:16:41 | 显示全部楼层 |阅读模式
Anyone know the model # and specifications of this older Lincoln AC/DC welder.It's for sale used but the advertisement doesn't give details; I can't read the model number nor the max amps AC nor max amps DC for the machine.  If you recognize the machine, could you advise me of what it is and what it can do.Thanks,Rick V
Reply:see if you can zoom into the upper right corner of the welder. the serial and code number are there.Looked through my lincoln file and did not find it. It might be a ac/dc 225 in a square case???
Reply:Looks like the Canadian version of the AC/DC 225 buzzbox.  I've seen Canadian unit code numbers begin with  'K'.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:see if you can zoom into the upper right corner of the welder. the serial and code number are there. - ccawgc
Reply:Similar machines in the same class. The miller will have a slightly higher welding amp rating.Either one will be a solid performing machine.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeSimilar machines in the same class. The miller will have a slightly higher welding amp rating.Either one will be a solid performing machine.
Reply:Originally Posted by duaneb55Looks like the Canadian version of the AC/DC 225 buzzbox.  I've seen Canadian unit code numbers begin with  'K'.
GMT+8, 2026-1-2 00:37 , Processed in 0.105813 second(s), 18 queries .
