What am I missing?
发表于 2021-8-31 22:16:40 | 显示全部楼层 |阅读模式
I hooked up a K2652-2 Magnum gun to one of my LN-25 wire feeders and the wire will not feed through the gun.  It gets to about where the curved part of the gun tube mounts to the straight part and stops.  I thought maybe something was wrong with that particular one, so tried another with the same results.  I have tried 6 brand new guns and ran into the same problem with all six.  I have dissassembled the gun and cannot see what the problem may be.  I can run a length of wire from the nozzle end down with no problem.  I was wondering if i made a short "jump liner" section if that may help, kinda like the Bernard guns use.  I am using 035 hard wire and these guns have 045 liners so i don't think that's a problem. Anyway, if anyone has any suggestions please respond.  Keep in mind that I am in a camp in the jungle of Ghana, so a trip to the welding supply store is out of the question.  Thanks.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I'm a dumba$$----The guns did not come with liners----problem solved except for the fact that i now have only 2 spare liners instead of the 10 that i thought i had---can't be cool ALL the time.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
GMT+8, 2026-1-2 00:35 , Processed in 0.096996 second(s), 18 queries .
