help with 300/300
发表于 2021-8-31 22:16:40 | 显示全部楼层 |阅读模式
Hey guys,   Hope you can help me. I just bought a used 300/300 and now I'm having a problem with the post gas flow. Well let me rephrase this, when the power is on the gas is flowing. I am suspecting the timer board on the welder, I need to know almost for sure before sending it out for a possible repair. Has this happened to anyone? What about some trouble shooting advice? Thanks!!!
Reply:Enter the Code # of your machine here:http://www.mylincolnelectric.com/Cat...ualsearch.aspxShould be trouble shooting info in the manual.Rex
Reply:Thanks, I had looked at that and was pretty sure that was the problem. just wanted to see if anyone had this problem and a repaired board fixed it. I will send it off to be repaired and when it comes back and everything works I'll post a resolution. Thanks guys!!!
Reply:Thought I'd post a resolution to my problem. I sent off the board to a repair shop. Once I got it back slapped it in and things were back to normal. hope this may help someone down the road.
GMT+8, 2026-1-2 00:38 , Processed in 0.093154 second(s), 18 queries .
