Couple of questions
发表于 2021-8-31 22:16:33 | 显示全部楼层 |阅读模式
Good morning.First question, is it ok to tack weld with smaw and finish weld with fcaw? Does one need to worry about the differences in the weld metal?Second, has anyone welded T-1 to C1045?  I hear it's hard to do, but can be done with the right preheat and interpass temps.  Tips from your success will be appreciated.Third, is there any truth in a statement made that if you are certified smaw overhead, you are automatically certified to weld fcaw overhead, even though they are 2 different processes?Thank you!
Reply:I was the supervisor on 1-mile of pipe tray in a Chevron refinery. The raising gang tacked with 7018, the welding crew ran NR-212.I've never seen it where SMAW certs were used for FCAW.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Welcome to the forum.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Thank you storeman and CEP.Why do they think QA has all the answers anyway?
Reply:Welcome to the nut house..... Errrr forum.Sent from my iPhone using TapatalkQualified & experienced at welding scrap metal
Reply:No smaw welding ticket qualifies you to weld with fcawJasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-2 00:35 , Processed in 0.098989 second(s), 18 queries .
