Measurements and Angles
发表于 2021-8-31 22:16:30 | 显示全部楼层 |阅读模式
What's the best way to guesstimate the measurements and angles for this wood rack?  Thanks in advance.
Reply:Looks like 4" siding which would make the deck boards around 6" which would make the log rack around 5' wide. Sides look to be around 5-8 degrees off 90 and material looks to be all 2" square tube probably 1/4" wall.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:I'm guessing 6" siding and 2x8 decking .Miller 211Miller T-bolt ac/dcVictor o/aMilwaukee ChopsawDewalt, Milwaukee minigrinderDelta drill pressDelta bench grinderair grinder, die grinderHF pipe benderHF horizontal bandsaw
Reply:Originally Posted by tekstarI'm guessing 6" siding and 2x8 decking .
Reply:They make phoo/measure programs for smart phones for borrowing ideas, but you can scale off what you have.  I'll bet its 2x6 deck and 2x2x1/8" tube. You wil have to guess the angle by printing up a couple pictures out and grabbing a crayon.
Reply:Here's how I rough estimate stuff - assuming the lean is about 1/2 of a board width.(Not to scale)Last edited by MinnesotaDave; 11-30-2014 at 10:28 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I'm guessing in the middle for height, if the guy used only one 24 ft bar of 2x2 tubing, sides would be 30" x 4pcs....(10 ft). + 2 rails x 5 (10 ft) ft + 6 cross bars 8" ( 4 ft)  assuming fire wood logs are about 16 inches long.This being a non precision project it can be done with a large +/- margin.edit: i can be completely wrong tooLast edited by snowbird; 11-30-2014 at 11:11 PM.
Reply:Got my hand poised over the big red "M" buttonGuestimate............yeah, guess and draw, who cares if it's absolutely perfectly absitively positively the exact angle.  Just do what works!!!!!!!!!!!!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammGuestimate............yeah, guess and draw, who cares if it's absolutely perfectly absitively positively the exact angle.
Reply:Thank you for all the great info in the responses.  Hell, I think someone even worked out how much stock I would need....lol. Very helpful, I was second guessing my self, but your help assured me I was on the right path.  Thanks again for the input!
Reply:Is there any way to delete a post?  Made a mistake in my math...  Last edited by sacherjj; 12-01-2014 at 08:21 PM.
GMT+8, 2026-1-2 00:52 , Processed in 0.096442 second(s), 18 queries .
