Miscellaneous Projects
发表于 2021-8-31 22:16:29 | 显示全部楼层 |阅读模式
Hey guys, just joined the forum recently. Thought I'd post a few random pics of some of the projects I've worked on. My real job is as an IT/Facilities Manager. I've only been at this a couple of years and still have a lot to learn but I really enjoy doing this work on the side.Mailbox for the house:Security bars for basement windows:Hand rail for ramp at church:2 sets of hand rails for steps. One set the lower post is anchored to concrete, on the other the posts go in ground:More to come.GraysOrnamentalIron.com
Reply:Nice handrails!Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:The mail box looks like one you could get at any hardware store, just with a fancy paint job on it. Did you buy the post and support bracket?The handrails look good though.
Reply:Nice work!ECAVE Still learnin'Lincoln AC225Lincoln 135SPHF ChopsawVictor O/ANumerous other items
Reply:Nice work.  What machine are you using?
Reply:Originally Posted by BistineauThe mail box looks like one you could get at any hardware store, just with a fancy paint job on it. Did you buy the post and support bracket?The handrails look good though.
Reply:Well then, that makes a bit more sense on the post. That turned out real well too then. I was wondering why you went to the trouble of building a mailbox that looks just like a store bought one, and then buy a fancy post to put it on. Now you need to make a custom box to go with the post and support bracket. Is that a trailer ball on top of the post?
Reply:Originally Posted by BistineauWell then, that makes a bit more sense on the post. That turned out real well too then. I was wondering why you went to the trouble of building a mailbox that looks just like a store bought one, and then buy a fancy post to put it on. Now you need to make a custom box to go with the post and support bracket. Is that a trailer ball on top of the post?
Reply:Looks really really nice!!!!
Reply:Nice job
Reply:Are the hinge pins on the security insert welded on one end? If not, pins can be tapped out to temove insert.
Reply:Originally Posted by TIGguyAre the hinge pins on the security insert welded on one end? If not, pins can be tapped out to temove insert.
Reply:Nice work.... Pics are great!! Your finished products, handrails and security bars look like they should have always been there.. They blend in with building that nice.Sent from my iPhone using TapatalkQualified & experienced at welding scrap metal
GMT+8, 2026-1-2 00:35 , Processed in 0.124598 second(s), 18 queries .
