Made four of these a work and just finished the last one Friday so i figured I'd post a pic. Pics are from a phone so they're a bit fuzzy.Made to fit onto the sides of a 3/4 ton box for our road crews so it's made from 2 x 2 x 3/16 tubing as they get beat up quite bad. Holes are for galvanizing. The piece over the cab holds the amber strobe on the front as well as the two vertical tubes hold an arrowboard that is made to be lowered with an electric actuator. As per usual, no drawings just "Make me 4 racks, you know what we want" Good thing about that kind of instruction, it can't be wrong as they don't have any plans ......Mike Attached Images
Reply:The expanded metal turned out beautifully. You sure did a nice job of building, and holding it square for the frame to fit that perfectly around the window opening."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice job! Does the angle on the back stay or is it just there to keep everything in place until the rack is installed? How many hours to build - on the average?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for the compliments guys.Does the angle on the back stay or is it just there to keep everything in place until the rack is installed?
Reply:Originally Posted by mrmikeyTemporary, the outfit that galvanizes them are savage. If that wasn't there chances are they would come back looking like a pretzel, still might actually.
Reply:That looks very functional with a pleasing line to it. I was looking at some car ramps I made about 20 years ago and had galvanised and there's not a sign of rust on them yet and they've been all over the place and not been particularly well looked after. I reckon galvanising's about the most cost effective coating where it's applicable. As you say though, you've got to make them "idiot-proof" if you want them back the way you sent them in."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Got 'em back the other day, body shop got them mounted and wired....Mike Attached Images
Reply:There ya go! Looks great mrmikey. Again, very nice job.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Good looking well made addition to the vehicle.
Reply:Nice work mrmikeBruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:Thanks guys....Mike
Reply:I take it you work for DOT..Miller Lake?
Reply:Yep, for 20 years....know the place?.....Mike
Reply:I think the galv. looks better than paint on this kind of deal.I'd almost bet the light bar, and hydraulics cost near as much as the steelThe drain holes are nice too. I'd probably make the thing, and have to go back and drill 'em because I didn't think of 'em when I made it"Any day above ground is a good day"http://www.farmersamm.com/
Reply:that a rack that looks like will last longer than the truck. nice craftsmanship.
Reply:Very nice mate.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Great job Mikey, that brings back memories. I retired after 32 years on the state DOT here in Illinois. We had lots of gifted welders and fabricators that could make or modify equipment to fit our needs. Keep up the good work and be safeSent from my iPad using TapatalkSteveLincoln IdealArc 250Lincoln SA200 1966 RedfaceSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:Looks really really good!!!! |
