Dimple Die option
发表于 2021-8-31 22:16:22 | 显示全部楼层 |阅读模式
Hey guys, I wanted the dimple dies and the hydraulic ram for them. Check out this price out of the Van Saant catalog!Well, I don't have that kind of scratch laying around anymore. So what I did was buy the dimple dies I wanted separately. I got the 1/2, the 3/4 and the 1inch sizes. Unfortunately, the 1/2 inch won't work with the hydraulic feature as it is too small. And I bought this:The hydraulic setup was 99bucks at Harbor Freight. I got the whole kit with a coupon for 74bucks. I only needed the ram. I already have an Enerpac air over hydraulic unit I use.  All the other stuff, including the pump is going to get re-sold either on craigslist, ebay or here in the buy trade sell.  I just thought it was a less expensive way to achieve what I wanted without getting gouged by "The Man".Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Did it come with the dies too?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I did the same thing I bought my dimple dyes from JMR direct, I dont know if there was much of a savings, and I also bought the HF set you bought and use the hand pump with the HF ram and it works out well, I dont recall the sizes but got a decent size set.  hope this helps.
Reply:I;ll 2nd Billybob, I run 2 sets of his dies and you can't go wrong with them for the past year. Flare 1/8" all the time.
Reply:gamble, what I got at Harbor Freight comes with everything you see in the picture. Yep, it comes with the punch and dies for knockouts. I didnt want the knockouts either, I just wanted the ram.Ron, I am too lazy to had pump. Just kidding. I already had the enerpac pump and I already have an enerpac hand pump. No need for the HF setup. Mick and LM,I will check them out!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Wow, those are cheap! Nice job on the mix and match. You'll probably recover a good chunk on selling the other parts. For the cost of the others, buy a lathe and make your own! 200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:I would love to make my own it looks easy as hell. I can go over to MarkBall2's pad and use his mil and lathe pretty much anytime he is home. But he said I need to harden them for them to work. IDK. So either you make em and they wear out soon, or you make them and harden them which probably costs more than to just buy them, or you buy hardened steel and ruin your tooling making them?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Pre-hardened steel needs to be ground, not machined in the typical way.We can make them out of a tool steel, then have them hardened.  Problem is the dimensions may change when the hardening takes place & require grinding to final dimension.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Interesting. Why not get tool steel, anneal it, machine it, harden, then temper? Would the heat really distort the piece that much? Like knife making.For a nuke power plant spec's, ok, but for general fab'ing I'd think it be fine. IMHO. What about chucking up in the lathe and carving it with a power tool, say a die grinder clamped into the tool holder? Best of both worlds?200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2026-1-2 00:52 , Processed in 0.114471 second(s), 18 queries .
