Is there something special about a Redface?I just picked up one that has been sitting around for about 2 years.They said it ran.Craigslist $145.It seems that people want these more. SA-200-F-163 SR# A-629225
Reply:Not running you could probably tripple your money on that one tomorrow. How about some pictures? Should be all copper innards, easy to work on and will weld quite smooth when put in shape. If you don't get many posts or replies it's cause we are all jealous if you bought a running Red Face for $145 and we won't talk to you. Just kidding, good luck."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:Is the all copper innard's the difference?I will post some picture's this weekend.
Reply:I for one refuse to talk to him unless he finds me one at that price too.Well . . . OK . . . Welcome to the forum johnk. . . . but that's it!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yes the copper is the main reason but the old machines have a very good rep all in all. congrat's on the purchase and welcome to the forum.1997 SA 250
Reply:It's worth more than you paid for it, just in parts! Let's see the photos...I've got drool drippin' out of my beard!!!Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:I thought it was only me who had the green envy as i read RedFace $145... got no real use for it, not a pipeliner but would look real keen in my shop. Duane got my mind straight however. thank you big D.Last edited by PapaLion; 05-07-2010 at 11:44 PM.Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Is that anything like... Army Jeeps - $50.00 ... ?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:I have a '72 SA 200 with aluminum windings. It seems to weld the same as the all copper red faces. I've heard as the aluminum windings heat up, you have to keep dialing your remote up to keep the same heat- the all copper red faces, withstand heat better so you'll keep a consistant heat. Is this difference between the aluminum and copper machines true? Anyone with first hand experience on this? Thanks. Have a good weekend.
Reply:There are some who swear they can tell a difference in them. Smooth buttery welds are a given with the SA 200 welder, provided it's properly maintained. In 1978, I think, there was a problem with a burnt shunt coil on a specific code #. From that point on there has been a prejudice against the aluminum windings. Truth be told few can tell what is aluminum wound and what is copper wound while under the hood welding.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Sounds like the deal you got is making everybody red in the face. I bought one one time for 2 hundred bucks. It ran but didnt weld. And had to drive up to the snowy mountains to get it. I spent alot of time and fustration into it before I figured out what was wrong. Finally lincoln help me figure it out. I replaced the commutator and that fixed the problem. I pulled one off of one that had aluminum windings that I have for parts. The commutator was a different part number than the one that was in it, also I think it was about a quarter or half inch difference in diameter. Lincoln told me it would be fine to swap them , it would just make my amperage slightly hotter than what settings would say. Anyway it welds fine and amperage seems to coordinate just fine w/ what the dials read.
Reply:Interesting. I must be one of those that can't tell the difference between the aluminum and copper. Both butter a 7018 rod the same like you said gizzard. Both weld the same to me- especially with 7010 rods, definately no difference there. Heck you could turn on the SA 200 and the Miller bobcat 250, throw the garage down down, hook the leads to either one and I couldn't tell you which machine was burning the rod. However, if it an't grey, you can't stay!
Reply:Well,I got the door's and hood off.As you can see it's missing a toggle switch on the right side.The bosch distribator has a wire that come's off it and goes up to the missing switch area.So I think the wire would go to the top(on) position of the 20amp new toggle switch I just bought.I think the bottom terminal of the switch would be the source,but were does the source come from?Does anyone have a eletrical print or something that can help.I drained the oil and it was black,better black then looking like milk coming out.I gunked it 3 times.I got a new thermostat and spark plug's to put in but had to order a oil filter.I will also inspect the point's.I did order the free cd from welding web and also read a lot on the American welding Society.I can turn it by the cooling fan,so at least I know it's not seized.I had the guy load it into my box truck,then I had to go to harbor Freight and buy a engine hoist just to get it out of my truck.It's not in great shape due to rust but hopefully it operate's ok. The hour meter read's 0765,I don't know if that's a lot or not. Attached Images
Reply:See thread http://weldingweb.com/vbb/showthread.php?t=41272 post #2. Answers many SA200 questions.Not a bad looking machine, better than I expected for the price you paid. A little TLC, some paint and you've got a machine to be proud of, hopefully!Last edited by gizzardgutz; 05-09-2010 at 02:00 PM.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:John, let's get you started in the right direction, first you do not have a distributor, you have a Magneto, the difference is when it rotates it creates it's own electrical field and spark without input from the battery. The battery is used to crank the starter. The advantage here is if your battery quits you can hand crank that old girl or jump it and keep right on welding. If you doubt me , just take a plug lead off and hold it in your hand while some one turns it over and you will soon see what I was talking about. just kidding. The wire from the Mag is to ground it out through a kill switch when it is running to shut it down. You will find a set of points under the cap. with a rotor much like a distributor. These usually come with the hand crank in a bracket on the inside of the machine, but are often long lost, Can still be had on ebay. Will it turn over with a good battery? check to see if a spark jumps from a disconnected spark plug wire to a good chassis or engine ground. The guys will be chiming in here if you have more questions, this is a favorite of many. good luck.Last edited by kolot; 05-10-2010 at 10:04 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:hey john where are you there is s guy in texas thay bjust went through my buddys red face everything like new machine now motor gen everything i think it cost him around 3500 but i am not sure but it is the best running machine i have seensa200 mo heat mo rod mo money
Reply:Originally Posted by kolotJohn, let's get you started in the right direction, first you do not have a distributor, you have a Magneto, the difference is when it rotates it creates it's own electrical field and spark without input from the battery. The battery is used to crank the starter. The advantage here is if your battery quits you can hand crank that old girl or jump it and keep right on welding. If you doubt me , just take a plug lead off and hold it in your hand while some one turns it over and you will soon see what I was talking about. just kidding. The wire from the Mag is to ground it out through a kill switch when it is running to shut it down. You will find a set of points under the cap. with a rotor much like a distributor. These usually come with the hand crank in a bracket on the inside of the machine, but are often long lost, Can still be had on ebay. Will it turn over with a good battery? check to see if a spark jumps from a disconnected spark plug wire to a good chassis or engine ground. The guys will be chiming in here if you have more questions, this is a favorite of many. good luck.
Reply:I will give you 545.00 and pay shipping.1990 SA 200Miller 225 Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Got it running today for about 1 minute only because it is in the garage.I changed the oil/filter and a set of plugs.I used the gas tank from my snow blower because I still have to clean the welders fuel tank.I am going to bid on a 1985 SA-200-f-163 this weekend,maybe I will get lucky and win.To clean the tank someone said to use BB's and Kerosine and shake the daylights out of it.I am open to suggestions.
Reply:Man you didn't buy that machine, you stole it! Haha j/k. The BB's and kerosene oughtta work OK. I use diesel and a handful of 1/4" ball bearings and it works good as well.RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25 |
