Buy this argon cylinder? ;)
发表于 2021-8-31 22:16:17 | 显示全部楼层 |阅读模式
Seems overpriced in it's current condition Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Nah just hammer it back and throw some 6010 on there. Good as new! Miller XMT 350 CC/CVMiller S74-DHobart Airforce 500i
Reply:Not a very smart seller, he should have rolled the '' inside inspection '' opening to the back.
Reply:I've not done an "inside inspection" - but I suspect a changing of shorts follows Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Yeah, it doesn't look like a real confident marketing tool to me Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:I would send it in for a hydro test to be safe.
Reply:Think I could fill that gap with my 110V HF MIG?  Or should I hammer it closed first and then 110 it?Sent from my SM-G900V using Tapatalk
Reply:Piece of duct tape and 2 hose clamps and she will be good as new.
Reply:Originally Posted by M J DI would send it in for a hydro test to be safe.
Reply:6010 is not the right rod, it has to be 7018.
Reply:that's going to buff right out.i.u.o.e. # 15queens, ny and sunny fla
Reply:Paint the whole thing flat black - it hides better than buffing Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:some 6013 on ac will make it right as raini.u.o.e. # 15queens, ny and sunny fla
Reply:Jb weld done deal wouldn't give him more then $320 for it though.Sent from my C811 4G using TapatalkVantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:Originally Posted by docweldersome 6013 on ac will make it right as rain
Reply:Add a zipper and you have a quick fill cylinder.
Reply:No that's so you can see how much argon you have left. http://www.philswelding.com
Reply:Looks like a good range target to me.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:you guys. does everything have to be a weld job? a little cardboard, a few wraps with some duct tape and you're good to go.i.u.o.e. # 15queens, ny and sunny fla
Reply:A split high pressure cylinder is nothing to joke around about guys. This thing could killsomebody if repaired incorectly.Better spend the big $ and fix it with some gorilla tape!My "collection":Homemade Stick WelderVictor O/A TorchAC 225Ideal Arc 250HF 90 Amp Flux CoreHF Mig 170Solar 2020 Plasma CutterPower i-Mig 140EHarris O/A torchHF Dual Mig 131140STAlpha Tig 200x
Reply:So Dave, did you buy it?  1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Go to where you have bottles filled, buy there.Bought 2 bottles at my local fill place, $100 each, filled with gas.my 2 cents
Reply:Originally Posted by Iain PA split high pressure cylinder is nothing to joke around about guys. This thing could killsomebody if repaired incorectly.Better spend the big $ and fix it with some gorilla tape!
Reply:Originally Posted by BoostinjdmI'm pretty sure these bottles do not get repaired under any circumstances.That said...  I'd kinda like to see it veed out and tiged without any super special, top secret procedure.  Then hydro'd to failure.  I want to see if the weld or another spot on the bottle would give first.  Disposed of afterwards of course.
Reply:Originally Posted by MinnesotaDaveI like this ideaI've repaired worse blow outs in a boiler. They held. Proper wps, proper execution of wps and use of proper materials all good.  But in no way would this ever be reused. To cheap to replace, not so with a boiler.
GMT+8, 2026-1-2 00:37 , Processed in 0.102189 second(s), 18 queries .
