General Lincoln Electric Question
发表于 2021-8-31 22:16:16 | 显示全部楼层 |阅读模式
Does anyone know if Lincoln will sell a machine without all the accessories? Specifically, the Square Wave 200 TIG machine without the torch, pedal, etc. Just the inverter and power cords. I already own a Lincoln 210MP with a TIG package so I have all the stuff I need, I just want the HF and AC options of the Square Wave.Thanks
Reply:If they don't, sell the extras on ebay. Likely do pretty well that way.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Correct me if I'm wrong, but the SW Tig 200 has a solenoid inside it and would use a one-piece gas/power connection for the torch, and you will have a 17V style torch with separate gas line to the bottle, meaning your torch won't plug and play between the machines.
Reply:Correct, weldinON. I just thought about this today while taking apart the weldcraft wp17 at work. Thanks and good thinking!Sent from my HTC6525LVW using Tapatalk
GMT+8, 2026-1-2 04:21 , Processed in 0.098328 second(s), 18 queries .
