I am getting ready to get onto a site where I will have to wear a hard hat and do a lot of overhead welding. I was considering a pipeliner hood with the AD lens already installed. I like the Jackson HSL100 with the wide lens as well but I've been told that it isn't good for overhead welding. I'd like to keep my cost around $200 or less. I'd like a hood with good visibility and that works well with a hard hat since I'll be wearing one at all times. Any suggestions?
Reply:I would go with the pipeliner. Be careful buying the large lens hoods, most places will only buy the 2 x 4 1/4 clear lenses. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Fibre metal pipeliner with arcone drop in AD lens.Set for many years.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Thank you. I just looked at the ArcOne lens and it looks like pairing that with the pipeliner is the way to go. Thanks again.
Reply:I do overhead MIG daily and use a pipeliner hood with s240 ArcOne auto dark. I have a Jackson Shadow HLS1 and it is horrible for overhead it lets a lot of light in from under the hood and my head gets burnt up.
Reply:The best helmet hard hat combo is Fibre-Metal with Quick locks. The most common helmet is a 4906 that comes with the quickloks and without a headgear and has a flip front. You just have to use Fibre-Metal hard with the quick loks. You can buy the Quick loks for the helmets separately but I've never actually looked to see if a Pipeliner is the right width to work on the hard hat. There's other hard hat adaptors but the Quick loks are the best in my opinion. An auto lens could be fitted to a 4906 or pipeliner but for everything might be a little over $200.
Reply:Another thing to take note on. With the hard hat you want to make sure you get a ratchet head gear. Before the ratchet head gear came out, hard hat welding hoods were a huge pain in the a$$. Even with the ratchet head gear they are still a pain in the a$$ just not as bad! Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:thankfully my hard hat welding days are behind me. as mentioned above by cep and welder dave you can't beat the ratcheting headgear and the quick loc combo Attached Imagesi.u.o.e. # 15queens, ny and sunny fla
Reply:On the construction site I use a fibre metal hard hat with a fibre metal shield and the quick lock package to connect them. I prefer the flip front window for grinding purposes. I use an auto dark insert lens in mine. useJasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I wear the fibre metal hard hat with no protrusions and use either a Jackson W10 HSL-2 flip front, or a pipe liner, with either one you will need a halo adapter to mount the welding helmet to the hard hat. The Jackson on fleabay is $32 shipped, hard hat and adapter $50, and you have a few bucks left for an AD shade if you want. You may want to note that when welding over head you are most likely to lose the hat and hood when you try to look up with the hood up. This is when the flip front becomes really handy, and at $32 shipped with the 370 head gear what's not to like?
Reply:The Lincoln Electric Viking 1740 looks good. It's under $100 though so I'm not sure about the quality.Last edited by Waller; 02-10-2016 at 10:34 AM.
Reply:I use a miller digital elite and digital elite. The head gear works very well compared to some othersSent from my SM-G920P using Tapatalk |
