Burned Knuckle
发表于 2021-8-31 22:16:14 | 显示全部楼层 |阅读模式
HELP!!   I have a bad habit propping on the metal i'm welding. I wear a tillman 820 aluminum glove with the pad on outside. I need to add a liner and wondering what ya'll use. I've looking at a carbon x liner and the Kevlar liners. http://http://www.galeton.com/black-...CesaAh6S8P8HAQhttp://http://www.magidglove.com/CAR...-SZ-CX100.aspxLincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:Google "tig finger".Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:Either tig finger or cut a finger off an old glove and put it over your burned finger area lol.Sent from my SM-G920P using Tapatalk
Reply:Burned Knuckle, what a great business name!
Reply:Work in reverse of where the heat is coming from.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I have the fig finger for dragging my hand....its my middle knuckle i'm cooking. I'm propping doing vertical up 7018 and Mig groove welds. I put the rod or gun right on my left hand and go to town. I've actually been putting the tig finger in-between the glove and shield and works great but i'm thinking its a technique problem hand work distance..... either that or like a kevlar insert?   Thanks.I suppose there is no reason why i shouldn't be dragging a tig finger up the workpiece.....just can't fit it on with the glove i'm using.Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:There is a double tig finger.  Should fill the bill.  Works for me.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:Don't prop on the metal you are welding. If you can't keep stable without propping, rig a secondary prop off table or what ever. Or... if possible, clamp a small piece of wood to metal substrate and prop on wood.Last edited by wagin; 02-07-2016 at 06:54 AM.Reason: adding more infoMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Yeah...i'll start practicing keeping off the metal. My knuckle looks like something of the walking dead!Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:Originally Posted by BrianCBurned Knuckle, what a great business name!
Reply:Originally Posted by storemanThere is a double tig finger.  Should fill the bill.  Works for me.
Reply:Originally Posted by FitnFusedYeah...i'll start practicing keeping off the metal. My knuckle looks like something of the walking dead!
Reply:Gotcha....i'll start tonight.Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
GMT+8, 2026-1-2 04:21 , Processed in 0.105263 second(s), 18 queries .
