Cummins turbo mount
发表于 2021-8-31 22:16:09 | 显示全部楼层 |阅读模式
After cutting down the manifold and making it center mounted I needed to clear the oil cooler so this is what I came up withLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:1/2" flange? Cut looks good. What plasma cutter and amperage?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Here are some more viewsLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is the manifold modificationLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Everlast 80s 10ipm at 55 ampsLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Awesome!!
Reply:Is that a cast iron header? How did it not crack on you? Looks like a fun project!
Reply:It is cast, good pre heat helps I welded it wth 308 stainles and seemed to work well and let cool in still air to ambent and had no crackingLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Awesome job. Nice and clean!
Reply:Nice. What's the motor going in?Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:4 cylinder cummins?12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:I putting the little 4bt in n a 2000  jeep tj sportLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Originally Posted by jbrI putting the little 4bt in n a 2000  jeep tj sport
Reply:Was this motor turbo charged before? It will be a little torque monster! Are you going to add more diesel to it? And how much boost?
Reply:It was originally turbo charged, I am trying to get my power from  the turbo with out adding alot of fuel, I am startig with a single charger (he341) but plan to compound with a hx30 to get a maximum of 50 psi of boost, I will add a external wastegate to regulate the turboLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Wow that will get those jeep tires spinning. Sounds like ur gona have to throw alot of fuel at it then. Are u doing any head porting? Will make more power on less boost.
Reply:Looks good.  I made an adapter somewhat similar a few years ago for my '96 Dodge.  Fuel is turned up somewhat on it, kept blowing stock turbos.  Decided to "upgrade" to a larger, more robust turbo.  Happened to have a turbo off of a 300 Mack laying around.  After I got my adapter made and bolted on, discovered turbo wouldn't fit because of interferance with shock/spring tower... so I ended up making more of an adapter plate for it.  Works fine either way.-------------------------Chemetron AC/DC 300 HFSnap-On MM300L Lincoln SP140 Lincoln AC/DC 225g Lincoln SA200 Lincoln SA200 Miller Bobcat 225GVictor torchesH&M and Mathey beveling machinesMcElroy Plastic pipe fusion
Reply:Installed a new oil drainThis is the one I did before moving the turboLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:It's awesome to weld some stuff. Well done.Old tools, trajan band saw, grizzly, delta,lincoln
Reply:Thanks ironmanLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:are you relocating the oil filter then? Looks as though it will hit the turbo if you don't.....Miller Dynasty 200Millermatic 211Instagram?.... find me @ WELD_MEDIC
Reply:Originally Posted by tig_21are you relocating the oil filter then? Looks as though it will hit the turbo if you don't.....
Reply:New oil cooler cover fits perfectly to relocate the oil filterLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Where did you get that remote port oil cooler? Is that OEM Cummins?Last edited by Alberta Farmer; 11-27-2014 at 08:32 PM.
Reply:Yes it is, will see if I can get a part number postedSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLSCool man
Reply:This is the jeep receiving the cumminsSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Looking good, what transmission are you using?Tim Beeker.
Reply:Gonna use the nv3550 till I break itLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:7.3 psd alt going on the 4bt cumminsSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
GMT+8, 2026-1-2 04:40 , Processed in 0.119370 second(s), 18 queries .
