Floating boat house frame
Reply:Looks good, hope you have a LOT of Styrofoam!Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:WOW! that is a lot of welding! What machine/method are you using?BrianMiller Thunderbolt 225 AC/DCEverlast 255 EXT with water coolerH.F. 170 Mig/Flux welderKent 3h.p. 9x42 milling machineHome Built 2"x72" variable speed 2 h.p. belt grinderHome built 9" variable speed 2 h.p. disc grinder
Reply:Sorry for the delay in response. Tapatalk didn't notify me that someone postedMost of the structure was welded with 2 miller 252sIt definitely was a lot of welding as all joints are welded solid , the customer is going to use the molded dock floats that will bolt under it, whole unit when completed weighs about 11kLast edited by nbmetalworx; 12-08-2014 at 09:01 AM.Reason: add on
Reply:This is the center of the boat house, it will have floats under it and be hinged on one end so he can pull a bass boat up on to it and fill the float with air to get it out of the water, let the air out to launch the boat |
