4x8 sheets of 1/4" plate
发表于 2021-8-31 22:16:03 | 显示全部楼层 |阅读模式
I have no interest in this at all other than to share with anyone close enough to Harrisburg,Pa. to be able to take advantage of this. At $119 a sheet even used it sounds like a deal if someone can use the material....they only have 500 sheetshttp://www.ebay.com/itm/500-SHEETS-4...66646828188717
Reply:Hmm harrisburg is only a 2 hour drive from here and I could stop at sandwich man for the best corn beef sandwich in the country while I am there.   Might have to price out so 4x8x1/4" sheets tomorrow.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Good Luck... Hope it helps anyone close to it.If you do go...See what it was originally used for. Just wondering how they acquired 500 used sheets with screw holes around the edges
Reply:use for flooring instead of plywood, hahahaI forgot how to change this.
Reply:One way to make a BIG welding table...
Reply:Originally Posted by mudbugoneOne way to make a BIG welding table...
Reply:Half off of what I pay here.The shipping to here would make it 4x what I pay here
Reply:"Great for bulletproofing your house..."Wow.I just built a 4x8' table with 1/2" plate, otherwise I'd be calculating my gas cost to drive to Harrisburg right now.  The picture doesn't seem to show any holes, btw.__David Hillman
Reply:"Great for bulletproofing your house..."Not really.That does seem like a good price.Tim Beeker.
Reply:That would make one HECK  of a welding bed or trailer bed!
GMT+8, 2026-1-2 04:42 , Processed in 0.097516 second(s), 18 queries .
