Buzzbox info
发表于 2021-8-31 22:16:02 | 显示全部楼层 |阅读模式
I just picked up an older Lincoln AC Buzzbox znd can not locate any inof on the Lincoln site.  It is an AC 225 S.  The code number on the plate is 8370-010.  I am taking it apart to clean out all the old spiders and clean up the contacts and would like to reference any tecnhical manuals that I can find.thanks
Reply:I found a user manual, pretty generic, but it does have an exploded view. How technical are you looking for it to be?http://www.lincolnelectric.com/asset...LN3/IMT237.pdfIt doesn't mention spiders, I think you're good to go.
Reply:Cleaning the contacts is a good idea. Your welder would be a 1983 model I believe. Clean it up, plug in to a 50 amp breaker, select an amperage and an electrode and weld away with one of the most reliable machines ever made.
GMT+8, 2026-1-2 04:41 , Processed in 0.098713 second(s), 18 queries .
