how do I sa200 pull the exciter bracket from the main housing
发表于 2021-8-31 22:15:57 | 显示全部楼层 |阅读模式
How do I pull the exciter bracket from the main gen I read the instructions on aws but dont see anywhere to hook the jaws ? I was thinking maybe a cam puller but that is to small . Any help is appreciated.1997 SA 250
Reply:First, you need to pull the nut, washer, and the "pressed on" centering ring.  The attached pic shows the parts and the cheap, two jaw puller to pull the ring.  Then the exciter armature will easily slide off.-Rhyno Attached Images07 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others... Originally Posted by RhynoBut, if I "all of a sudden disappear....  ...." hopefully I didn't suffer too much....
Reply:Did you read this thread?http://www.aws.org/cgi-bin/mwf/topic...4044;hl=PullerDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Here is a link to one of my posts.  It shows the Puller Plate that I made to pull the exciter housing.  Along with the plate, I used a different two jaw puller to get it done.-Rhynohttp://weldingweb.com/vbb/showthread.php...839#post36183907 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others... Originally Posted by RhynoBut, if I "all of a sudden disappear....  ...." hopefully I didn't suffer too much....
Reply:thank's guys I found a puller today made by otc and mac a snapon truck I saw had one he took on trade it is like rhyno but one solid bar I dont have a means to fab much with the welder down but thanks again.1997 SA 250
GMT+8, 2026-1-2 02:58 , Processed in 0.100862 second(s), 18 queries .
