Viking Helmet 700G or 750S
发表于 2021-8-31 22:15:57 | 显示全部楼层 |阅读模式
Trying to decide between the 700G and the 750S Viking helmet. I am just a beginner with a stick welder. Any suggestions between the two?
Reply:Here is the main difference between the two... Do you want cheater lens capability or do you like having a standard front lens cover. The 700 and 750 are just the beginners in Lincoln's new line. If you are looking for a Lincoln helmet, I would wait just a couple more months. I had a "prototype" helmet in here that I was doing a demo on, and I would def recomend it over the 700 or 750. It was cheater lens capable, had a std outside lens, was lightweight, had the inside controls on the shade, sensitivity, and delay, AND had a brand new headgear which held itself up when "clicked" in the up position. It looked pretty neat and I can't wait to see them come out soon.
Reply:Did it use the standard flat cover lenses?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Yep, the 4x5 Std. Outside Cover Lens
GMT+8, 2026-1-2 02:59 , Processed in 0.069257 second(s), 18 queries .
