I need some dimensions for the 2pc linkage for the electronic idle solenoid
发表于 2021-8-31 22:15:56 | 显示全部楼层 |阅读模式
Can someone give me the dimensions for the 2pc linkage for the electric idle solenoid?I need to know:The diameter of the hole that connects to the carburetor.The diameter of the hole that connects to the pin that goes in the solenoid.The diameter of the holes in the straight piece.The length and width of the slots in the piece that has 2 bends.I don't have one on hand that I can measure.Thanks!http://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
Reply:The diameter of the hole that connects to the carburetor. = 3/16”The diameter of the hole that connects to the pin that goes in the solenoid. = 3/32” roll pinThe diameter of the holes in the straight piece. = 3/16”The length and width of the slots in the piece that has 2 bends. = 3/16” X 3/4” Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thank you very much!http://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
Reply:Looks like I need a couple more dimensions if you can help me out.I need the distance the slot starts from the edge of the part.The length of the slot.The distance of the first hole from the unbent edge of the longer piece.Just for clarity mine has holes in the bent piece and slots in the shorter unbent piece.Thankshttp://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
Reply:Would a picture help? Very simple bracket to make, with a picture. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Here's the one I made. My holes must be off on the longer piece My slots look the same distance from the edge as your part.http://www.facebook.com/groups/sa200weldersCurrent machines:Hobart G600 Powered by 1967 Chrysler LH-318 (Project)Hobart GF-250(Traded)68 Redface81 Blackface
GMT+8, 2026-1-2 02:58 , Processed in 0.134149 second(s), 18 queries .
