SA-200 RPM check
发表于 2021-8-31 22:15:55 | 显示全部楼层 |阅读模式
Ok I have 1977 Sa-200 with Mag,How do i check the RPM?,,,,I have a dwell(RPM) meter but where do I hook it to?Thanks:
Reply:Originally Posted by welder99Ok I have 1977 Sa-200 with Mag,How do i check the RPM?,,,,I have a dwell(RPM) meter but where do I hook it to?Thanks:
Reply:Or use a volt meter. You should have 90-volts dc at the receptacle on the front of the machine and 66-volts dc at the studs on low idle. 88-95 at high idle on the studs, and 125 to 130-volts dc at the receptacle. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thanks Guys for the info.....I needed to adjust the idle ,,,the voltage thing worked great....Thanks again,this place ROCKS...when you need information.
GMT+8, 2026-1-2 03:09 , Processed in 0.112952 second(s), 18 queries .
