Good deal or no?
发表于 2021-8-31 22:15:52 | 显示全部楼层 |阅读模式
good deal or not? to pass up on a used miller maxstar 150stl  for 550 dollars? the only thing missing is the 220 plug and I have no idea if you can buy them or not.. I only have 110 at the moment but possibly getting 220 in the near future so the 220 adapter would be somthing id need later on.Last edited by 1AgKid; 02-14-2016 at 03:55 PM.Mullets&Pullets
Reply:What do you hope to use it for ?  It isn't much good with 6010 if you hope to weld any pipe or do any type of pipe practice.  If I was buying it and couldn't get the original plug id just put a 220 plug on it and make a pig tail adapter for 110...Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:I can't tell from the picture if it's got the 120 plug wired direct to the welder or if that's a twist lock. We have ours at work set up with a 30A male twist lock on the welder power cord and a couple adapters for 120 and 240 made from hardware store SO cord and plugs/receptacles
Reply:Not a bad deal..Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:hope to use it for random jobs not any particular ones...Mullets&Pullets
Reply:Nice little unit for scratch/lift tig. 150 amp scratch tig torch for under $100.00, gas with flow meter and your off to the races.
Reply:what about stick? is this a decent machine for stick welding?Mullets&Pullets
Reply:I've used the STH version to TIG weld and it works good. It is a very light and compact machine. For $550 i would go for it - the lowest I've seen near me is $750. Not to mention they also run well of a 5+kW generator if you ever need to do mobile work or repairs. You can buy the 220v adapter from Miller or make a little pigtail adapter yourself. Either way its not a easy fix.1988 Big 50 Diesel CC/CV1982 Weldanpower 225/2101968 SAE 300 motor generatorMaxstar 200SD2015 AHP 200x"The trouble with our Liberal friends is not that they're ignorant; it's just that they know so much that isn't so." - Ronald Reagan
Reply:Just make sure to try before you buy- if those things go BOOM they cost more to fix than they're worth.A few weldersA lot of hammersA whole lot of C-clamps
Reply:some guy wound up buying it before I could go look at it Mullets&Pullets
GMT+8, 2026-1-2 04:51 , Processed in 0.075154 second(s), 18 queries .
