Tamper proof hold down nut
发表于 2021-8-31 22:15:51 | 显示全部楼层 |阅读模式
So the boss lost the key pin to this thing.  You insert a key pin into the hole and it allows you to unscrew the nut.  I have searched and searched online to find out how to open it or a manufacturer. Any help would be greatly appreciated!!!!!
Reply:Interesting, what is the nut on?
Reply:Got a lot of hits searching for "security nuts" and fasteners, but nothing like that.  Does it spin freely and the key engages the threaded portion???   Or will the nut just break off without using the key?    It almost looks like a release on a pressure vessel of some sort???Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:I would look to the providers of security nuts & etc for the electrical utility industry.  Brooks Utility Products, or someone.  They should know what's out there.  They won't tell you how to get in there.  That is their business.  But if you are for real, there might be a way. http://www.brooksutility.com/p/locking_hardware"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumI would look to the providers of security nuts & etc for the electrical utility industry.  Brooks Utility Products, or someone.  They should know what's out there.  They won't tell you how to get in there.  That is their business.  But if you are for real, there might be a way.
Reply:Nut splitter. Grinder with a cut off wheel to split the nut in half. Torch to wash the nut off the stud. All of these will both destroy the nut and save you a lot of headache having to screw with it.
Reply:Ok, I appreciate it. Major head ache.  Yes it does spin freely and then the key engages the threads.  Its actually the lid to a bomb/survival shelter.  But as I stated he lost the pin.   The manufacturer no longer in business, go figure.   I'm def going to call Brooks and see if they have anything. If not I guess we'll fire up the torch.  Just hate to screw the thing up.  A survival shelter doesn't do much good if you cant get in. If the zombies attacked he'd be in trouble.  On the flip side I guess someone would have a hard time getting in,  Although the thing is made of fiberglass.  Not sure how much good that's going to do at worlds end.  Anyway thanks again!
Reply:Open end wrench to turn the nut and a pin punch of the appropriate diameter to push through the pin hole to engage the threaded internal portion.  Done.Or remove the nut portion with a zip wheel or nut splitter or whatever and then deal with removing the rest of the threaded section(s).  The best laid schemes ... Gang oft agley ...
GMT+8, 2026-1-2 03:09 , Processed in 0.112160 second(s), 18 queries .
