I'm not a pipe welder/fitter but I just watched a youtube vid of a guy Tig welding a pipe joint with the rod going thru the pipe to the other side thru the open root and holding the Tig gun opposite the side your standing on with a lense tapped to the pipe to look thru, no helmet just clear safety glasses, I'll bite, is this for real or us this guy a hack. Look for dynasty 350 " looking thru the gap technique". Sorry I haven't figured how to import links and pics.thanksMiller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
Reply:Originally Posted by missfireI'm not a pipe welder/fitter but I just watched a youtube vid of a guy Tig welding a pipe joint with the rod going thru the pipe to the other side thru the open root and holding the Tig gun opposite the side your standing on with a lense tapped to the pipe to look thru, no helmet just clear safety glasses, I'll bite, is this for real or us this guy a hack. Look for dynasty 350 " looking thru the gap technique". Sorry I haven't figured how to import links and pics.thanks
Reply:The county I live in we have a nuclear submarine base. I've talked to several welders who work there. They use this technique all the time. We have a member here, he calls it shooting the gap.Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:This technique allows the welder to achieve a slight amount of reinforcement on the inside of the pipe. This is handy for the over head section of a pipe weld with the tig process. I've never been able to get reinforcement on the inside of the pipe for the over head position of the weld. I can get it flush, but never a crown on the inside. This welding technique allows that.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Probably this one.He's 110% legit. See how he stuffed himself in over the pipes? He also calls out to his helper to make slight changes to the Fine Current control as he goes 'cause he can't run the remote due to his position.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:. . . or this one . . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by missfireis this for real or us this guy a hack.
Reply:Been there, done that. Some field weld positions leave you no choice. I can do ok shooting the gap. I know welders that make you weep with how pretty the root is whwn they shoot the gap. sent while goofing off at workLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Originally Posted by soutthpawThat sounds like fieldres. Do you mean this video yeah he is a very talented welder and 100% uv safety glasses will prevent arc flash, however unless you are as skilled as he is. Use a welding hood.
Reply:Yeah that kid is an amazing welder! I'd like to be stuck in the shop with him for a few months! Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400 |
