Rocket Stove Ideas
发表于 2021-8-31 22:15:44 | 显示全部楼层 |阅读模式
Im thinking about building a Rocket stove for the shop. Seeing if anyone has built one. and what to build it out of.Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Aren't they pretty cheap to buy?  If I had to build one, I'd probably opt for stainless, because I already have some, and because it won't rust after having the crap burned out of it.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:3/16 steel would probably be good. There are alot on YouTube. How big is your shop?
Reply:I made one the other day out of 3/16 4in sq tubing. It was just for a test run. I'm planning on making a bigger one soon.
Reply:this guy made one that doesn't seem to be a full time feeding job. with a larger fire box. if you have pics to share please post them... If somebody knows thee ratio for the size of flue vs feed tube and chimney outlet that could be valuable info too,
Reply:There are lots of ideas out there on good rocket stove design.. and there are some pretty crappy designed rocket stoves as well.There is some good information here as to the design, there are some players on youtube as well that have some good things going as well. rocketstove.org is a good place to start, there is lots of information and design ideas. Plus, they have pdf's that discuss design and math.I have a little prototype stove that I feel has good results so far. Built a skillet attachment recently and bought a 24" skillet.. gonna do the "official" Youtube temp/boil test soon. Gonna cook some bacon, eggs hash browns and sausage too!  Would like to get going on the oven box and hot water heater as well.. Not enough hours in the damn day. Too late to be out there now.I did a thread on the one that I built. I don't have any videos on the net, but could possibly compress and email you a video, maybe ftp if you dig. I can give you the measurements off of mine. Meant to do the same for another person, but forgot. Good suction.. that'll bring some jokes.http://weldingweb.com/vbb/showthread.php...ype&highlight=-NicheLast edited by NicheFab; 12-12-2014 at 01:21 AM.
Reply:Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:So that is what a rocket stove is  never heard of one. I'd go at least a 12 inch pipe. And put a door on it or your wood will burn super fast. Can't believe he didn't cut the hole first. That guy is not the best fabricator. But he's a good stick welder!
Reply:Seen some made of beer kegs. Sent from my SM-T537R4 using Tapatalk
Reply:One thing I have learned is there is a forum for everything on the web.  Even rocket stoves.http://donkey32.proboards.com/I have been a member for a few yearsLincoln mig-Pak 180, Leather gloves, vice grips, a couple screw drivers, needle nose pliers, a file, dog, cat and a bird
Reply:Its about 30'x40' shop we are always working on cars in their so I thought it would be nice to have one.  I do have some Square tubing laying around and some pipe ill have to some measuring now. post pictures sooner or laterLincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
GMT+8, 2026-1-2 03:09 , Processed in 0.104721 second(s), 18 queries .
