For Sale: Miller Maxstar 200 STR DC Stick & TIG with Leads and Torch
发表于 2021-8-31 22:15:41 | 显示全部楼层 |阅读模式
For Sale: Miller Maxstar 200 STR DC Stick TIG with Leads and Torch. Get it before it goes on Ebay!This was rescued from a pawn shop about a month ago and has been tested fine at about 100A with the included 6011 rod. It also includes the pictured TIG torch but no controller or flowmeter is included. The leads are 1/0 and are 10'. Includes a new Jackson 200A stinger as well as the required Dinse connectors. I don't need it as I have a Synch 300 that will do the same at 10 times the size and 20 times the weight!  PS: this is wired for 220V single phase with the usual NEMA 6-50 plug. It also comes with a previously installed 4-pin recepticle that must have been used for 3-phase. You could also wire it for 110V if desired.Of note is that the included 12'? torch has not been received yet (bought off Ebay). It is a Harbor Freight air-cooled unit from a 91149 TIG welder and should fit the Maxstar perfectly. I'll test it and let you know with an update to this post. It will probably include a limited amount of expendables, if any.Instead of the torch I received a Direct TV dish and receiver--a seller mix-up--what the hell do I do with that? (the seller said to just keep it) I just got done arguing with the wife to keep her from switching from cable. After all is said and done, you end up paying more with all the required receivers for each TV (4). Well I guess I would have one of the four already--if it even works...Shipping weight on this unit with cables/rods is 60lbs and will be shipping via DHL from zip 32771. Refer to attached for more info. Thanks!Freindly WW price: $850.00 plus shipping... Attached Images Attached Imagespg1max200str.pdf (97.3 KB, 114 views)pg2max200str.pdf (76.2 KB, 46 views)pg34max200str.pdf (99.5 KB, 54 views)MM252 w/30AMM140 w/o AS w/SM100 w/CO2TA ArcMaster 185 TIG/StickTA 85 TIG/Stick LunchboxHobart (Miller) AirForce 625Hobart AirForce 250ciVictor O/A (bored)Lincoln Patriot AutoShade (freebie)45ACP for those stubborn jobs...
Reply:Miller Maxstar 200 STR, bidding starts at $777.77: http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1Campbell Hausfeld 70A Stick Welder, bidding starts at $19.95: http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1MM252 w/30AMM140 w/o AS w/SM100 w/CO2TA ArcMaster 185 TIG/StickTA 85 TIG/Stick LunchboxHobart (Miller) AirForce 625Hobart AirForce 250ciVictor O/A (bored)Lincoln Patriot AutoShade (freebie)45ACP for those stubborn jobs...
Reply:PS: The Maxstar sold for $900 and the CH for $20. Thanks for looking and check out my Miller Synch 300 for sale at: http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1Thanks for looking! Bob.MM252 w/30AMM140 w/o AS w/SM100 w/CO2TA ArcMaster 185 TIG/StickTA 85 TIG/Stick LunchboxHobart (Miller) AirForce 625Hobart AirForce 250ciVictor O/A (bored)Lincoln Patriot AutoShade (freebie)45ACP for those stubborn jobs...
Reply:I would like to buy it,Please call 213-216-2133 Alexor e-mail [email protected] Originally Posted by mccutterFor Sale: Miller Maxstar 200 STR DC Stick TIG with Leads and Torch. Get it before it goes on Ebay!This was rescued from a pawn shop about a month ago and has been tested fine at about 100A with the included 6011 rod. It also includes the pictured TIG torch but no controller or flowmeter is included. The leads are 1/0 and are 10'. Includes a new Jackson 200A stinger as well as the required Dinse connectors. I don't need it as I have a Synch 300 that will do the same at 10 times the size and 20 times the weight!  PS: this is wired for 220V single phase with the usual NEMA 6-50 plug. It also comes with a previously installed 4-pin recepticle that must have been used for 3-phase. You could also wire it for 110V if desired.Of note is that the included 12'? torch has not been received yet (bought off Ebay). It is a Harbor Freight air-cooled unit from a 91149 TIG welder and should fit the Maxstar perfectly. I'll test it and let you know with an update to this post. It will probably include a limited amount of expendables, if any.Instead of the torch I received a Direct TV dish and receiver--a seller mix-up--what the hell do I do with that? (the seller said to just keep it) I just got done arguing with the wife to keep her from switching from cable. After all is said and done, you end up paying more with all the required receivers for each TV (4). Well I guess I would have one of the four already--if it even works...Shipping weight on this unit with cables/rods is 60lbs and will be shipping via DHL from zip 32771. Refer to attached for more info. Thanks!Freindly WW price: $850.00 plus shipping...
Reply:Call me 213-216-2133  or E-mail [email protected] name is Alex
Reply:Having a little trouble with reading comprehension there Alex?Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:lol  was  SOLD in 2006 bummer a day late an short a buckidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Newb's you gotta love em eh???Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:That does take some digging to go back that far in the FS pages. Wish some people showed the same motivation searching rather than asking the same questions over and over.Oh well.
GMT+8, 2026-1-2 03:08 , Processed in 0.125032 second(s), 18 queries .
