Mag Drills
发表于 2021-8-31 22:15:22 | 显示全部楼层 |阅读模式
Need opinion, I'm getting a Mag Drill and have the choice of the drill motor having either a MT3 or a chuck, I know I can get a MT3 chuck but which would be more benificial. Presently looking at the Milwaukee Mag Drill, but have choice of chuck or MT3,ThanksMiller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
Reply:I use a Milwaukee mag with chuck.  It' very useful.  I use it on my welding table instead of a drill press.  I drill and tap holes in the table (plate of 1/2 steel)  for threaded visegrip clamps for production projects.  One thing though, you need thick steel for it to grab good.  It would slip if you were trying to drill 1/8" for example.  I have used it on 3/16 with mild pressure. For larger holes, I use the hole hawg bits.
Reply:get the mt3 so you have options, I have never regretted mine.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:missfire  -  Don't buy anything that won't accept a standard 1/2" drill chuck and an arbor for roto-broaches, also known as annular cutters.   Opus
Reply:If your looking to buy a good mag drill I would buy a hougen mag drill.  I currently have 3 mag drills, one is an evolution brand, good English made drill (new ones are made in china) and two hougens one is the 90 degree low clearance version and the other is the standard version.  They all have been used and abused.  The hougens kick ***. I did have a Milwaukee mag drill before it grew legs on a job site.  But I wouldn't buy another one. When using a mag drill you really shouldn't be using twist bits, you should be using annular cutters.  I do have the chuck for my bigger hougen but I can't even remember when the last time I drilled a 1/2" or smaller hole with it.Last edited by Xtreme Fabrication; 07-21-2012 at 07:16 PM.Reason: SpellingLincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:that is annular cutter.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Double post, please removeLast edited by Xtreme Fabrication; 07-21-2012 at 07:15 PM.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Appreciate the info, looks like I'll get the MT3. Thanks againMiller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
Reply:I've got the Morse Taper and a MT chuck that fits my Milwaukee Mag drill.No complaints.Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:fein is partnered up with a company that makes real nice mag drills made in iowa. theyre called sluggers or something. Cant really remember but they are slick. just sayinLocal 597
Reply:" fein is partnered up with a company that makes real nice mag drills made in iowa "Fein bought Jancy, the old man was getting way old and the kids had zero interest in running the business.My favorite Mag drill:http://fabequip.com/equipment/magnet...etic_drill.htmAt annular cutter costs it doesn't take very long for the self feeders to pay for themselves.
GMT+8, 2026-1-2 03:09 , Processed in 0.130512 second(s), 18 queries .
