HF Spot Welder Tips
发表于 2021-8-31 22:15:21 | 显示全部楼层 |阅读模式
Has anyone found a replacement tip for the HF spot welder? The HF near me does not carry them.  They will sell you a new welder, just not the tips.
Reply:If you are talking about the pin welder they sell, Eastwood carries tips that should fit.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:I have had good service from Harbor Freight when I ordered a part for an engine I purchased from them.  I hope you get the same good service when you inquire about your spot welder tips.  It took a few weeks, not days, to get the part from China.  Because the tips are a consumable, I suggest you consider getting a supply not just what you immediaditely need.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Found replacement tips for the upper tong of the Harbor Freight 120 volt spot welder online. Posting the info in this thread in case others would be interested.Copper Alloy Spot Welder TipNorthern Industrial MIG/Stick 200 Welder(3) Soldering irons and some flint n' steel.
GMT+8, 2026-1-2 02:59 , Processed in 0.123557 second(s), 18 queries .
