Hi guys,I currently need to upgrade my bench grinder. I have had this HF grinder for many years and its time to change the motor as it's not working properly anymore. I am planning to buy a motor with the following specs -Enclosure: TEFC Phase: 3 Hz: 60 Frame: 56Cas an option was thinking of Baldor, and did find one on here that is compatible to the specs i want to get https://www.mrosupply.com/product/25...eneral_Purpose what are your thoughts of Baldors? is it normal price=quality ratio? What are you personally using and do you like it what you have?Thanks in advance,John
Reply:No matter what motor you choose... check craigslist and ebay for local deals/auctions.I scored a local 5HP 3 phase Baldor motor on ebay for $27 a couple months ago.wasnt even aware HF made a 3 phase bench grinderESAB Heliarc 252
Reply:yeah, 3 phase motors are not really a high demand item so they can usually be had pretty cheap used....miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Google makes good motors they are a little more money but good qualityMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Putting a Baldor motor on a HF grinder?Why not just get a Baldor grinder?"The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Within the last year, I bought a Baldor 812REhttp://home-and-garden.webshots.com/...80433075oOWpGQ It was some of the best money I have spent. I have three Baldor grinder/buffing machines in my office, too. They are all 21 years old. They have had zero problems. They start and run every day just like the first day. Baldor motors are out of Fort Smith, AR. They respond quickly to questions and requests. They do cost a little more, initially, but in the long run will serve you better, cost you less, are more dependable, have tons of torque, and will not disappoint you. I would save my money, and wait, save and wait a while longer to get a Baldor. You will not be disappointed. Good luck on your search!TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder |
