Lincoln 250L question.
发表于 2021-8-31 22:15:16 | 显示全部楼层 |阅读模式
I have a Lincoln Power Mig 255C equipped with a 250L gun.  I want to convert this gun to slip on nozzels and someone told me that the Tweco #2 gun parts would work on the 250L.  I would like to try to confirm this to be true or not.
Reply:It is true. There are two ways that you can convert that to slip on nozzles. You can use a 52 diffuser with a 32 Insulator and a 22-50 slip on nozzle or you can keep the 52FN diffuser and use Tweco #4 parts - 34A Insulator and a 24A62 Nozzle. Any aftermarket company will work too. Tweco consumables are highly overpriced. Check out Profax - they make cheap quality consumables
Reply:Thanks!I went with the #2 parts.
GMT+8, 2026-1-2 02:59 , Processed in 0.075233 second(s), 18 queries .
