SA200 gasket info needed
发表于 2021-8-31 22:15:15 | 显示全部楼层 |阅读模式
Anyone happen to know the part number for an oil pan gasket and front seal on a F163 engine?  Is this something I could pick up at a local auto parts?Thanks in advance,CharlesMillermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:http://www.agkits.com/Continental-F1...GasketSet.aspxCheck this out.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:And this http://www.motorpowerinc.com/pricing/f163.htmlDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I just, -maybe a two weeks ago- bought Fel-Pro F-163 gaskets at NAPA, but I had to be persistent.There was no way to look them up by application in the Fel-Pro book or the computer. Counterman tried Continental, Teledyne, Lincoln, Massey, Towmotor...Finally he let me look it up myself in his old books, (McCord or Victor I think) and then the 'puter crossed that number to the current Fel-Pro number. And get this... they were in stock!I asked him in all seriousness; what they would do if John Doe walked in? How could they  possibly expect to sell in-stock the gaskets if there's no way to look ‘em up?There was a question about two-gear vs three gear cam drive. I'll post the part #s tomorrow. I'll bet your local NAPA has a set on the shelf too.Good LuckLast edited by denrep; 10-06-2008 at 09:34 PM.
Reply:Originally Posted by crawlerAnyone happen to know the part number for an oil pan gasket and front seal on a F163 engine?  Is this something I could pick up at a local auto parts?
Reply:Denrep and Tozzi,Thank you very much for the info.. I will go shopping now.CharlesMillermatic Passport PlusMillermatic 200Millermatic 350P with PythonXMT 304 /w S-64 feeder and 12RCDynasty 300 DXVictor O/APremier Power Welder for my trail junk.
Reply:If you have to order, check out Weldmart. They have an SA200 troubleshooting a parts CD they'll give you. I purchased a water pump, front seal, and oil filter from them yesterday. Should be here tomorrow. Good luck with yours.
Reply:The best service around when you need parts identified and sourced quickly are the folks over at www.detroitdieselmiami.com . They have over 20 years of experience in the parts support industry. Give them a call if you have any diesel engine rebuild questions or pricing for parts and rebuild kits. 1-888-642-6460.Thanks-Alex Paret
Reply:Originally Posted by denrepF162 and F163Oil pan set: Victor - OS20509FelPro OS30236Front cover set:(included front seal)Victor - JV894FelPro - TCS54182Valve cover:Victor - VS38083FelPro - Purchased FelPro, but I lost the number.While we're at it, F226 (six cylinder)Head gasket:Victor - 986SFelPro - 7191SI was careful with the numbers, and they were purchased 09-2008 at NAPA, but confirm fit for yourself.Good Luck, Hope it helps
GMT+8, 2026-1-2 03:08 , Processed in 0.124191 second(s), 18 queries .
