Fan Motor
发表于 2021-8-31 22:15:15 | 显示全部楼层 |阅读模式
Have an AC-225 and the fan started running a little rough. Can it be lubricated or needs to be replaced? Don't have an operators manual, bought it used.
Reply:Hi Ned,I can't comment exactly on the AC-225 fan motor but most welders use a pretty simple fan motor that can be lubricated by dropping a few drops of oil onto/into the bearings at each end.  Looks at it this way; you got nothing to lose by oiling it.Further, the manual for the AC-225 should be available on the Lincoln Electric site.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Thanks, will give it a try.
GMT+8, 2026-1-2 05:05 , Processed in 0.106753 second(s), 18 queries .
