Crank start pipeliner
发表于 2021-8-31 22:15:13 | 显示全部楼层 |阅读模式
If a pipeliner with a 4cyl cont has a crank start,what would the approximate age be.Are they even worth buying?
Reply:Last crank start back up was in 1962.  Anything that is a crank start is the best ones lincoln ever made.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:I am going to go pick one up today,I will post picture's in a day or 2.
Reply:First hand crank was in 1938. The last was in 1983, the diesels were introduced 1970.All pipeliners had hand cranks it was the backup starter for the machine.The pre 80's machines are awesome they are copper wound they weld awesome.
GMT+8, 2026-1-2 03:09 , Processed in 0.084464 second(s), 18 queries .
