Inch Diameter Corrected
发表于 2021-8-31 22:15:12 | 显示全部楼层 |阅读模式
I've many problems when i have to convert ID in IDC please could you explain me , what's the procedure or method to convert my unity in IDC, thanks
Reply:I think that you are wanting to know how to convert metric mm to inches.  1" = 25.4 mm
Reply:No is not this conversion, i'm looking for inch diameter corrected IDC in piping welding unity
Reply:i never heard of it
Reply:I think I know what you want but I do not know where to get that info. Hopefully a pipe fitter will come along and know.
Reply:Do you mean nominal diameter (i.e. 2 inch) to actual diameter (i.e. 2" nominal =2.067" for schedule 40 pipe)? Use a chart as is contained here:https://en.wikipedia.org/wiki/Nominal_Pipe_Size . Take the outside diameter(2.375" for 2 " pipe) and subtract the wall thickness twice (.154" for sch. 40 x 2" pipe) . Note that the OD tolerance is + 1/64" & -1/32".   If this is not what you mean clarify your terms  ID=inside diameter?? and IDC=inside diameter corrected??---Meltedmetal
Reply:Is not this, nominal diameter no,i'm looking for IDC. ID of joint example Ø16" one joint is =16 id,but to convert all the diameter of spool we multiply this diameter to acoefficien of conversion to obtain IDC, like 1 joint of 10"= 10x0.8 in IDC and 12"=12*0.8 IDC its acoefficient to convert all the differents diameter of pipe in a same diameter IDCorrected. Do you understand what i want to explain you ?
Reply:Not ever learning trig, bryc, this is all way above my paygrade. Hope you find what you need.                                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by brycIs not this, nominal diameter no,i'm looking for IDC. ID of joint example Ø16" one joint is =16 id,but to convert all the diameter of spool we multiply this diameter to acoefficien of conversion to obtain IDC, like 1 joint of 10"= 10x0.8 in IDC and 12"=12*0.8 IDC its acoefficient to convert all the differents diameter of pipe in a same diameter IDCorrected. Do you understand what i want to explain you ?
Reply:I prefer LMN, or QRS, or maybe ABC.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:I've new definition, it's the correction of schedule, i explain is a correction for the same diameter but with different schedule, we correct the Ø16" shc 40 to obtain Ø16" sch sdt. we can explain me.
Reply:i find that the correction of diameter is fonction of a chamfer type; example Ø= 12" std ep =9.53mm IDC= ID x K (V chanfer ) for std K=1 =12idx1 = 12 IDC;for the same diameter ep=10.31 mm the K=1.11 IDC = 12 x1.11= 13.32 IDC;do you understand me ?
Reply:Yeah, sure!! As soon as I understand I'll start building that nuke power plant I've been wanting for yrs.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Sounds like he is assuming that schedule 40 has the same thickness for each pipe diameter.If this is true, then a coefficient (multiplier) for schedule 40 could be applied to every outside diameter (OD) to find the inside diameter (ID).Similarly a different coefficient for schedule 80 would be used to find ID for any given outside diameter.The problem with this approach is wall thickness increases as the pipe diameter increases.Last edited by MinnesotaDave; 02-16-2016 at 03:16 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thanks, Dave. I think you just explained more than he's been able to for this old trig deficient fart!!                                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2026-1-2 02:59 , Processed in 0.093978 second(s), 18 queries .
