Help with a project
发表于 2021-8-31 22:15:08 | 显示全部楼层 |阅读模式
Go here and ask the question how much force (weight) does it take to START TO bend but still can spring back to original without damage stainless steel solid rod 2 1/2" in diameter 12" from the fulcrum point If there is any calculators out there that will work I'd be glad to know that too. Thanks. Sent from my iPhone using Tapatalk
Reply:Originally Posted by shawntkeatingGo here and ask the question how much force (weight) does it take to START TO bend but still can spring back to original without damage stainless steel solid rod 2 1/2" in diameter 12" from the fulcrum point If there is any calculators out there that will work I'd be glad to know that too.
GMT+8, 2026-1-2 03:09 , Processed in 0.107878 second(s), 18 queries .
