Things to do with Old Transformer?
发表于 2021-8-31 22:15:08 | 显示全部楼层 |阅读模式
I found an old Harbor Freight 90 amp flux core welder. Its 120 volt input it not a DC output but ac so it's an ac transformer. It would not feed wire and little board looked burned.Its not worth fixin to me but theres gotta be something cool I can do with the transformer. Any ideas?
Reply:Use it for a power supply with taps for multiple voltages. Make a small spot welder for thin  gauge material.ChrisAuction Addict
Reply:To make it a dc transformer you just add a diode bridge. It'll be "dirty" dc unless you also add a capacitor. Google "harbor freight welder mods".Eventual master of the obvious, practitioner of "stream of consciousness fabrication".  P.S. I edit almost every post because because I'm posting from my phone and my fingers sometimes move faster than my brain.
Reply:Gut the thing and make it a lunchbox.  It would be funny to carry it on to a job site.You might add a bridge rectifier to the main transformer and make a DC power supply.  Add an adjustable regulator.  Use it for an electrolytic derusting setup."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Doorstop comes to mind Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Send it to nytom.
Reply:Originally Posted by OldendumGut the thing and make it a lunchbox.  It would be funny to carry it on to a job site.You might add a bridge rectifier to the main transformer and make a DC power supply.  Add an adjustable regulator.  Use it for an electrolytic derusting setup.
Reply:If it's a wire feed, it was DC somehowExperience is something you get right after you need it
Reply:Originally Posted by Fred sIf it's a wire feed, it was DC somehow
Reply:Originally Posted by M J DSend it to nytom.
Reply:the board that is burn is probably the controller board for the wire speed control. so bypass it and use it for a small stick welder. just close or bypass the contacts if it has them.
Reply:See how far you can throw it.
Reply:Attachment 273351Last edited by denrep; 02-18-2016 at 01:51 AM.
Reply:Wow, FCAW on AC must be interestingExperience is something you get right after you need it
Reply:Remove the secondary windings,  replace with 1 or 2 wraps of heavy welding lead wire,  and make a spot welder.  That'll give you super high amps,  and a voltage low  enough that it won't shock you. http://www.philswelding.com
GMT+8, 2026-1-2 03:09 , Processed in 0.099315 second(s), 18 queries .
