Intercooler piping
发表于 2021-8-31 22:14:58 | 显示全部楼层 |阅读模式
Started modifying aluminum intercooler pipingSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:What's it going on? What filler rod are you gona use?
Reply:Not sure what it's going on, job just walked in, I'm gonna use 4043 fillerSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Nice fit up there.  Looking forward to the welding pics.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:I have done this many times. I use 5356. I also made many pressure test jigs just for this purpose.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Originally Posted by TJSI have done this many times. I use 5356. I also made many pressure test jigs just for this purpose.
Reply:Do you use 4043 because it cracks less easy?
Reply:Originally Posted by motolife313Do you use 4043 because it cracks less easy?
Reply:More of a preferece. 5356, higher tensile strength and shear, more ductile, does not turn black when anodizing. However it is tempurature sensitive to above temps of 150 F. I have never had an issue though. I like the way it flows with my inverter.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Gotter welded Sent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Another lookSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Great pics of the welds. 12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTGreat pics of the welds.
Reply:Originally Posted by jbrThanks
Reply:Customer was in a hurry to get going and these were the only one I gotLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Here is one I over looked in my phone Sent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
GMT+8, 2026-1-2 05:04 , Processed in 0.103571 second(s), 18 queries .
