death in the family !!
发表于 2021-8-31 22:14:54 | 显示全部楼层 |阅读模式
i was honored , when my father handed me the oxy/act set , that his father handed to him so many yrs. ago!  this handy lil cutting torch was... PERFECT !!  always did what u asked of it w/o and lip. ... as i laid the lil torch down and turned to grab a fitting , i heard the worst sound ever , a 1 ton flat bed truck , running down my lil torch body.  ,  ,  , i turned to look .. the torch was dying , slowly , still lit , gasping its last breath . its body and blood veins , crushed , only the tip , tubes and  cutting handle remain . the air adj. screw was blown out and its lil plunger was lost forever . prolly saving my life in the process . ....Anyway what im trying to say is : i need a cuttin torch body for a :Marquette ...Aero Jet....22-111 . also the plunger, under the air  adj. screw, under the cutting handle.  ANYONE .,have a clue where i might be able to get these parts ? it was my grandfathers . and my fathers whom are both long ago passed. im sick about the disaster that took place . may your welds always hold to anyone w/info !!!!
Reply:Post PICS of the torch so others can recognize it or parts thereof more quickly.
Reply:Frame it and put it on the wall!Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Did you manage to kill the guy driving the truck for running it over? I would have.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:One of these ? :http://www.ebay.com/itm/MARQUETTE-AE...item2c6038edae
Reply:the pic is very dark , my cam/corder low quality. sorry . total length of this cutting assy. that you see is ..7.. inches. the handle is raised from where the plunger should be , directly behind the handle hinge pin , there is an air adj. screw that holds plungr in assy. in the center of that screw is a hole , that is where the plunger actually is . it sticks out the air adj. screw hole . when pushed, the handle , pushes the plunger into the hole causing air to enter the tube , accelerating the flame to cutting temps. that is my NON-PROFESSIONAL , explenation . i hope that is as clear as mud to everyone out there Attached Images
Reply:They turn up often on Ebay and are usually inexpensive.
Reply:If a sub would do.Some Harris bodies are supposed to interchange,don't remember which anymore.Might do a google for Harris and MarquetteThis is one model number different.:http://billswelderrepair.com/files/marquette_110.jpgLast edited by Bluewelders; 10-26-2011 at 06:42 PM.
Reply:Originally Posted by BlueweldersOne of these ? :http://www.ebay.com/itm/MARQUETTE-AE...item2c6038edae
Reply:They go much higher complete. Look for just the body or just the attachment and they go for far less.
GMT+8, 2026-1-2 05:02 , Processed in 0.099403 second(s), 18 queries .
