tig cooler purchase? How to check..Photos!!!
发表于 2021-8-31 22:14:50 | 显示全部楼层 |阅读模式
Hi guys. I have a miller cooler that might be availible for me to buy. I plugged it in and she kicked on. How can i test the pump, and other things that make a cooler a cooler? I just want to do  quick test.thanks for all your advice. thanks.
Reply:also, whats it worth in this condition?
Reply:I have a couple of these.    Fill the thank with water and turn it on...should get a steady stream of water out.   Put your thumb over the outlet and it should squirt like a garden hose with your thumb almost covering the outlet port.   This will show pump can generate good pressure.   Really not much to them but the pump itself is the most expensive partTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I suppose you could put a pressure gauge on the outlet but I'd imagine if it pumps water it will work.
Reply:wheres the tank on these things. may be a silly question, but i dont know. thanks.
Reply:the fill hole is under the metal plate with two thumbscrews under the word "radiator"
Reply:i thought so, thank you. ill check it at work tomm.
Reply:whats the thing on the left? is that water level check? its the cylindrical whitish thing. flow indicator. thanks
Reply:Its pumps water. Whats its worth
Reply:The very dirty sight glass on the left showes that water is flowinf though the hoses from the torch, but won't show anything without a torch connected.   If there is a blockage in the hose or torch head then u will not see return water flowing through it.  There is an over pressure bypass on the supply side of the system if there were to be a blockaageTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I'm not sure on the price, I have a watermate 1a that I paid $50 for.  I think the boy found it dumpster diving and I had to take the cover off and tighten some hose clamps but it works good. I just lucked into that.I'd guess $150-$200 for the one your looking at, someone else should know better.
Reply:I opened the cover. There is a slight grinding sound that seems to be comming from the water pump fan area. Is there anything i could do to quiet it?    I paid $75 for the cooler. also, it pumps water, but is that all it does? do i check anything else?Last edited by loolagigi; 07-31-2012 at 07:23 PM.
Reply:The tag on the pump is 981 0001147. Can anyone point me in the right direction of where i can buy one if i need to? Thanks.
Reply:It looks like an Oberdorfer pump. I had a blackface Radiator-1 that was in similar condition when I got it, main reason being was that the pump shaft seal was worn and leaked all over the chassis. Contacted Depco Pump (Oberdorfer parts dist. in Fl) for a replacement seal and out of curiosity asked about a new unit and hard rebuild kits...the prices were higher than I would ever invest in that particular machine. Popped in the new seal and made a paper gasket to seal the halves back together. Runs great.mantooth
Reply:As I mentioned the pump is the $$ part.  $200-$300 for a replacement..Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:FWIW, I found this:  "Oberdorfer pumps are known for being noisy. They also require soluble lub in the water to lubricated."http://www.oberdorfer-pumps.com/"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:there is not much to those pumps.  I would suggest taking it apart and cleaning everything out then reassembling it...  also take the motor off and the tank cover off and clean out the water tank.  I bet its full of crap inside...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawthere is not much to those pumps.  I would suggest taking it apart and cleaning everything out then reassembling it...  also take the motor off and the tank cover off and clean out the water tank.  I bet its full of crap inside...
GMT+8, 2026-1-2 05:05 , Processed in 0.104539 second(s), 18 queries .
