Trailblazer 251 - Stick is dead
发表于 2021-8-31 22:14:49 | 显示全部楼层 |阅读模式
Hi ya'll,Thanks for your help in advance.  I have a Miller Trailblazer 251 that will not draw an arc on the stick mode.  I have AC and the unit will instantly melt rod if I switch to the wire setting.  I only have the stick setup for this machine.  I have checked all fuses and and cleaned the cable connections to be sure but with such a good arc on wire I don't believe connections are the problem.  The id plate is missing off the machine so I don't have a serial number.  The unit was welding great and then quit like I had a ground issue but it won't even draw an arc directly on the ground.  Any thoughts would be appreciated.Thanks.
Reply:Sounds like operator error! Lol just kidding...kinda...
Reply:You may find a SN sticker inside the unit.  White, about 1/2" wide and about 1-1/2" long.  If it's still there.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:On further investigation there is no sticker with ser. # in the machine.  I have inspected the inside and find no melted or broken wires and all connections are tight.  There is a faint spark when you try to draw and arc on the ground but not even enough to excite the exciter.  Anybody have an idea of what to check next?Thanks
GMT+8, 2026-1-2 05:04 , Processed in 0.074541 second(s), 18 queries .
