Anyone have a part number for plug wires? F163 w/ fm mag. Also need plugs, radiator hoses and thermostat numbers.Thanks guys.Last edited by welder44b; 07-23-2010 at 12:37 AM.
Reply:OK, with the magneto you need copper wire core plug wires. Auto parts usually have a reel of the proper wire, cut to fit and your good to go. This means taking your old wires in so the new can be cut to fit. Mark where they go individually. New ends will have to be purchased and put on each wire individually also.NAPA has the plugs, hoses and thermostat, unless they're like the one in my hometown and simply can't find anything without the part #'s provided for them. The SA 200 sticky in the Lincoln section of this forum gives the part #'s for all except the thermostat. I couldn't find a # here either. But, if you want an address for premium SA200 parts go here: http://hybriweld.com/ They'll answer your questions on the phone too.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money. -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Stumph Welding supplies, $20 bucks and the right ones"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251 Syncrowave 300 30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200 1 short hood SA250 SAM 400
Reply:NAPA has universal metallic wire core wire set you cut to length has terminals & boots with it. Run non resistor spark plugs with those wires with a mag too. Lincoln wire numbers are in the parts list. Operators manualshttp://www.mylincolnelectric.com/Cat...ualsearch.aspxParts listhttp://www.lincolnelectric.com/produ...e/partsnav.aspLincoln manuals IM-179 for R57 vacuum idler or IM-277 for electronic idler give instructions on timing and other settings of carb, linkage & governor.
Reply:I've had extremely good luck with Denso L14-U plugs. My Local Napa can't / won't order them in, so I order from this site. http://www.sparkplugs.com/results_cr...14-U&x=39&y=15Dont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400 |
