Sealed can of 7018?
发表于 2021-8-31 22:14:39 | 显示全部楼层 |阅读模式
Local shop has an older 50lb sealed can of 7018 rods that I can get for less than $0.50/lb....any reason I should pass?  I know the can is still sealed, so the rods should be dry, but has anyone ever opened a sealed container and found contaminated rods?
Reply:No not contaminated rods, but broken rods tho! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:If you're going to burn them up practicing, I'd say go for it.  If they're meant to make you money on a job, then you be taking your chances.
Reply:You bought 50lbs, you got 50lbs.  They didn't say all the 50lbs would be attached to the rodsEdit: before some dood posted between posts  Response to CEP's post"Any day above ground is a good day"http://www.farmersamm.com/
Reply::d..................."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yeah, you may find that a lot of the flux has been knocked off from the can being abused. I wouldn't even use them for practice but that's just me.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Just popped into my head, has nothing to do with rodsAbout time to cube the cows.  K'kins shows up from work pretty soon, she always helps.  She's a WOMAN!!!!!!!!!!!!!!!!!!Carry on"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I just bought a 50lb can of older 7018 as well.   The can was not all beat up so I figure the rods should be ok.   Brian
Reply:Originally Posted by farmersammAbout time to cube the cows.
GMT+8, 2026-1-2 05:03 , Processed in 0.072392 second(s), 18 queries .
