What do you think of this welder?
发表于 2021-8-31 22:14:39 | 显示全部楼层 |阅读模式
Hi all, while back decided against getting the hobart becuase i couldnt spend that money on just a mig welder.. so ive been doing alot of research and found the everlast powertig 185 http://www.everlastgenerators.com/pr...owertig-185-dvand was wondering what you all think? is it worth somthing considering? is it not going to be powerful enough? i dont want to spend more then 900 so this looks to be in my budget. Thanks
Reply:I don't mind heading down to Harbor Freight for tools that will either be used sparingly at best or for those 'sacrificial' models I don't want to lose one of my better tools on. On tools that see a fair amount of use and I hope to keep around for the rest of my days, I buy the better quality product because over time it has proven to be the cheapest alternative. Now to each their own, but I can't think of a job where I would need a 'sacrificial' welder and I'm not going to be using a welder sparingly...so you wouldn't catch that machine in my shop. Best of luck with whatever machine you decide upon.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Look into the Lincoln Power MIG 210. It is a new offering from Lincoln and will have long term support.  It is just under $1,000 online.http://www.lincolnelectric.com/en-us...olnElectric%29GravelThe difference between theory and practice is that in theory there is no difference.
Reply:I can't speak specifically to the Everlast 185, but I have owned and used an Everlast 250EX for about 4 years now with no issues whatsoever.  I have other choices for welding in my garage, but for quick and easy tig welding the 250EX continues to be my go-to machine.  One of the first things I did when I set up the 250EX was add a water cooler because I didn't trust the torch cable to stand up to 250 amps without the extra cooling.  I have never used it for the SMAW function as I have a dedicated stick machine, but usually default to the mig welder instead.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Originally Posted by GravelLook into the Lincoln Power MIG 210. It is a new offering from Lincoln and will have long term support.  It is just under $1,000 online.http://www.lincolnelectric.com/en-us...olnElectric%29
Reply:Originally Posted by AKweldshopDude,He couldn't tig alum with that!OP,Here's a video for you.
Reply:Originally Posted by Drewster2016im also thinking though, if im just gonna teach my self how often will i be welding aluminum? like is it worth the money to get an AC/DC machine
Reply:I have that 185   It's a good simple machine.  Does a good job on aluminum.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:after doing some reseach i am considering buying the everlast pa 160 STH
Reply:What's your location ?  If you want stick , I would look for a Miller Thunderbolt AC/DC or a Lincoln tombstone AC/DC. Check craigs list and buy for around $200 and use the rest of money for goodies. Do you have adequate power ?
Reply:I'm a bit confused on what you are looking for. First you mentioned MIG, then you suggested an AC/DC TIG machine, then a stick welder?      I suggest deciding what you really plan on welding most and then pick the best machine to meet those needs.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawI'm a bit confused on what you are looking for. First you mentioned MIG, then you suggested an AC/DC TIG machine, then a stick welder?      I suggest deciding what you really plan on welding most and then pick the best machine to meet those needs.
Reply:From what I have read you might want to look at the I-mig 200 from Everlast.  110v/220v capability with mig and stick functions that should cover just about anything you want to do in your garage and have the balls to weld some thicker material if necessary.  If you decide to weld aluminum add a spoolgun.  It can be picked up for $650 + shipping.
Reply:Originally Posted by RoadhunterFrom what I have read you might want to look at the I-mig 200 from Everlast.  110v/220v capability with mig and stick functions that should cover just about anything you want to do in your garage and have the balls to weld some thicker material if necessary.  If you decide to weld aluminum add a spoolgun.  It can be picked up for $650 + shipping.
Reply:I meant what I said.  Nobody pays list price for welders.  Look online and you will find much better deals.  Ebay is where you can find the deal I told you about.
Reply:looked and i didnt find anything for a pirce around 650 i did find the 211i if thats what you mean?
Reply:An ac/dc TIG is a very nice machine the have in the home shop. Can weld any project that needs welding (aluminum or steel) and no sparks and cleaner over all.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by Drewster2016looked and i didnt find anything for a pirce around 650 i did find the 211i if thats what you mean?
GMT+8, 2026-1-2 05:03 , Processed in 0.117469 second(s), 18 queries .
