Fork It
发表于 2021-8-31 22:14:35 | 显示全部楼层 |阅读模式
I have been asked several times if I could do brush clean up work with my Kubota B 7800 and couldn't because I lacked a set of brush forksif you have ever tried to do this with a standard bucket it's a PITA ... like trying to scoop up a plié of bailing wire what little you get in the bucket wants to fall back out because it's tangled up and you don't want a load of dirt mixed in So this is an old design my father made quite a few sets of these in different sizes and both loader mount and 3 point hook upjust going to alter it for quick attach / detach ... and maybe a future thumb load holding thingThe material is 2 x 2 x .250 tubing that is what I have on hand and was scrap from another project that we are done withmaking the points is easy used a wood stake for the template make the cut lines and break out the gas axeplasma cutter would have been easier for thisAnd the Trail Blazer went to the shop to be repaired so were using the old but reliable Millermatic 35Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:The points after weldingCut to equal length with my Rage 3 dry saw mounted on a folding mount it folds down and has wheels I am doing the real welding when the TB get back from the shop I don't want it fail so 7018 1/8 esab atom arc is what I will be usingBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I like that design, I think I'll borrow it if you don't mind :-). Two questions, what anchors the top and what prevents the bottom from being push back?.....Mike
Reply:I got the Trail Blazer back and it's not working right so it's going back Monday  I wanted to put most of the stress on the bottom of the bucket and not have it just swinging around only hanging on by the top quick mounts and needed it to not interfere with normal loader operationso I came up with using 2 pieces of 4 x 4 x 1/2" plate cut in a L shape and welded inside to the sides of the bucketThis holds it in place and doesn't get in the way while keeping the stress pushing down onto the bottom of the bucket and against the lock platesBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:That should work great!  I did some brush work with a very similar setup once and it worked well.  That machine also had a thumb thing on top like you're planning.  With the thumb you can move some serious brush piles!How do you like your Rage saw?  I think I'm about to get one.Sent from my C811 4G using Tapatalk
Reply:Now the top quick mounts were a pita because I had to buy an odd size piece of angle iron and I am trying to keep this light as possiblebut I could only find  a piece of it a little thick...overkill 4" x 7" x 1/2"  I would have liked to have found it in 3/8" thickIt locks over the 3 x 3 x 3/8 angle that is welded to the top of my bucket for the hooksbut you see how it basically works and mounts so I can detach it quickly and the only stress on the top hook up is the weight of the whole assembly the pushing and raising stresses are all kept to the bottom of the bucket and the two locking platesI will post the rest laterBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I have had my rage  for three years now and still love it cuts that tubing nice quick and burr freebut cutting 250 wall wears on the blade so i'm going to have to sharpen it soon..i should have bought another of the blue blades so one on the saw and one to sharpen it takes some time to sharpen them with the HF machine I haveif you look at that one photo I posted were my ground clamp is that was cut with the rage 3 nice and smooth ..I didn't even grind itLast edited by killdozerd11; 01-06-2014 at 04:00 AM.Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Very nice build! I built something close to that years ago for my tractor, but not near as heavy duty as yours. But eventually I ran into a good deal on a grapple for a skid-steer, cut all the mounting brackets off and built ones to fit my tractor. A grapple makes life so much easier! Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Is that 420 hydrostat ? I miss my 955 Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by BurpeeIs that 420 hydrostat ? I miss my 955
Reply:Originally Posted by 7A749Hey CEP, that's a nice little tractor
Reply:Looks good!! What's wrong with TB?Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Looking great Al! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I stole your idea also. Gonna make it work on my Kubota M7040. Proverbs 4:23My company welds.
Reply:Good idea killdozer
Reply:Did you run third function Hydraulics on your loader? I've got a JD 790, I'd like to be able to run the implements off my Kubota and Skid Steer, on the JD also. Did you run it off the rear AUX, and just add a control? Originally Posted by CEPVery nice build! I built something close to that years ago for my tractor, but not near as heavy duty as yours. But eventually I ran into a good deal on a grapple for a skid-steer, cut all the mounting brackets off and built ones to fit my tractor. A grapple makes life so much easier!
Reply:John Deere calls it a "Power Beyond Kit". Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Okay. 790 doesn't have a rear SCV.  Originally Posted by CEPJohn Deere calls it a "Power Beyond Kit".
Reply:That should move some loose brush quickly. Nice work AlMiller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Originally Posted by BlackbeardWhat's wrong with TB?
Reply:The TB went to running from extreme high rev to below normal idle no happy medium ..it didn't matter if switch was in auto idle or run so I took it back to airgas I got it back Friday and guess what it went back to doing it again but I could put the switch in run and it would run at speed so I could get this project done they had it for 3 weeks So back to airgas it went todayMiller rep said it's kohlers problem they say it's millers problem all I know is it's only 4 months out of warranty and I paid 400.00 for them to fix it and it's not fixedthe mechanic said it was the coil to that I say BS he said it worked fine when he tested it now he says that miller sent service bulletins out about bad connectors on the ECM harnessBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:My tb had issues with the plunger getting corroded and sticking making it idle and run crappy. I've cleaned and oiled it a few times. Now I have a bad board. The amperage drops down if you turn it up past 150 amps. Change potentiometer with negative results. Gonna fix it soon.Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Oh that sucks Blackbeard...Hope you get it fixedWas going to tell CEPthe reason for me building them like I did was two of the jobs I went to look at people had dumped trash of all kinds on these places along with a lot of dirt that I am going to have to sort it out and load the dumpsters or trucks with a minimum of dirt ..This was the quickest way I could think of to do itBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Killdozer, that's a great idea.  Mad Max would have loved that pimp ride in Barter Town! Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by killdozerd11Was going to tell CEPthe reason for me building them like I did was two of the jobs I went to look at people had dumped trash of all kinds on these places along with a lot of dirt that I am going to have to sort it out and load the dumpsters or trucks with a minimum of dirt ..This was the quickest way I could think of to do itOne guy I worked for had a grapple for the skid steer it worked great for demo work Had thumb on the excavator that was good for demo work alsoSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:That will work. Are you gonna make wings for it next ? Might help protect the tires.
Reply:Another handy attachment to have is pallet forks. I copied Ingersoll Rand's design to a degree. I move my SA-200s around all the time with these. I put padeyes on it so it can go on the 3-point hitch for heavier lifting. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by Mick120Nice....I'm in the process of building a similar design for one of my customers.
Reply:CEP, what dimension/thickness of tubing did you go with on the forks, and would you keep it the same if doing it again?
Reply:I like your brush forks - I would suggest one addition (assuming you are as hard on stuff as I tend to be). Your design keeps the forks from trying to twist the tube they are welded to.But it also makes them into a lever arm that will push up on the tube, using the bucket lip as the fulcrum, causing a bow on the lower tube.Two extra pieces, triangulated up near the ends of the upper bar, to support that lower tube would prevent this.They would start near the middle of the lower tube and angle out towards the ends of the upper tube.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by cwhCEP, what dimension/thickness of tubing did you go with on the forks, and would you keep it the same if doing it again?
Reply:Here's a quick set of brush forks I made in a pinch after sandy took down over 100 trees on my property. I used some 1x1 I had laying around. They worked great with the light pine branches anything else would have pretzel'd them.
Reply:Originally Posted by MinnesotaDaveI like your brush forks - I would suggest one addition (assuming you are as hard on stuff as I tend to be). Your design keeps the forks from trying to twist the tube they are welded to.But it also makes them into a lever arm that will push up on the tube, using the bucket lip as the fulcrum, causing a bow on the lower tube.Two extra pieces, triangulated up near the ends of the upper bar, to support that lower tube would prevent this.They would start near the middle of the lower tube and angle out towards the ends of the upper tube.
Reply:Originally Posted by CEPThe rectangular tubing is 2” x 4” x 1/4” wall, 8.81 pounds per foot. The forks are 40-inch long. This coming summer the fork attachment will be 13-years old. My tractor will pick 1,300-pounds, I have placed shackles, and chokers in the holes at the end of the forks to pick things, and stalled the loader. No I can't say I would change a thing. Couple years ago I did come across a good deal on a set of T-1 warehouse forklift forks. When ever this rectangular tube gets bent or rust out I'll replace them with the T-1 forks.
Reply:While I am waiting for people to get their stuff togetherI figured I would play and take pics for my CL addsThese are from my phone cam and as you can see they work well Sent from my SPH-D700 using Tapatalk 2 Attached ImagesBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11I got the Trail Blazer back and it's not working right so it's going back Monday
Reply:Very Nice Al!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Like how you brought the tubing to a point.  I would never have thought of doing that"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Very nice Mick! WOW that is some heavy wall DOM on top of the forks.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by Mick120At least it won't break......
Reply:Nice build MickDon't ever say can't break it some moron will prove you wrongSent from my SPH-D700 using Tapatalk 2Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Fork moving heavy stuff by handI figure i can adapt the basic frame and mod it for pallet forks also similar to the ones mick did so they can be adjusted that way it uses the same locking tabs already in my bucketif i ever get time for my own projectsBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2026-1-2 05:04 , Processed in 0.099874 second(s), 18 queries .
