uphill beads er70s-6
发表于 2021-8-31 22:14:35 | 显示全部楼层 |阅读模式
I know ya'll like to see pictures of welds, so I was welding some crane stops, and decided to go uphill. Need to work on keeping it more uniform. Miller 452, 21volts, wire speed 280, .035 wire, 75/25 argon-co2 at 30 cfh. I-beam W18x24 welded to 3/4" A36 plate.I have more pictures but having trouble finding them. I will post the rest as soon as I find them. Attached Images
Reply:Looks good man!!
Reply:Might just be the picture but it looks cold, toes look like they didn't wet in well.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by Murphy's lawLooks good man!!
Reply:Originally Posted by SquirmyPugMight just be the picture but it looks cold, toes look like they didn't wet in well.
Reply:Nothing wrong with that weld.  Looks great. Fine work.Two turn tables and a microphone.
Reply:cajunw; not too shabby at all.i.u.o.e. # 15queens, ny and sunny fla
Reply:Keep up the good work
Reply:Very nice lookin welds, much more even than anything I can do these days.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Here's a few more pictures. The last one is two 1/4" plates that makes an L. Attached Images
Reply:Not bad at all. You definitely are improving each time. Are you starting to be able to read the puddle yet?Bottom picture the toe shown a top is a lot more jagged than the one shown at the bottom. Again I think you may be favoring one side over the other. I'd also like to see the motion tightened up still. I'd like to see you move across 2 to 3 times as much which would smooth out the bead and the edges some..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks for the replies.DSW, yes I can see what you are saying. I don't get to weld that much anymore, mostly just fit and tack, and let the younger guys weld, which I don't mind.
GMT+8, 2026-1-2 05:04 , Processed in 0.192072 second(s), 19 queries .
