Easy money
发表于 2021-8-31 22:14:34 | 显示全部楼层 |阅读模式
Had this come in to be welded for a 7.3 powerstroke Sent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:Looks good. Any idea what he was using it for I run a couple 7.3's and cant figure out what that would be used for?
Reply:I'd bet exhaust temp or turbo boost psi sensor.
Reply:air/fuel ratio sensor
Reply:Thanks guys! I am not exactly sure what it's forSent from my iPhone using TapatalkLONGEVITY 250EX w/ 25' weldcraft cs310 torchTorchmate w/ Hypertherm powermax 85   withFLASHCUT CNC PRO SERIES CONTROLS
Reply:EGT exhaust gas temp sensor.Nice work!12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTEGT exhaust gas temp sensor.Nice work!
Reply:Propane injection maybe? Looks good.
Reply:Yeah if it is intake it can be propane, nitrous, maybe alcohol or methane injection? Or could be a simple temp sensor.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:A couple of questions and a little advise.  What was the flat or flats for on the threaded piece?  Since you brought up money, what do you charge for doing something like this?  The fit up of the threaded piece to the tube looks pretty good, did you put a radius on the one end of it?  While I am guilty of it as well, it really isn't good to load up one side of your vise like that.  You should have set it on something and put the piece in the middle of the vise.  You would also be better suited with a 4 flute endmill rather than the 2 flute.
GMT+8, 2026-1-2 05:03 , Processed in 0.073403 second(s), 18 queries .
