Black and decker magnetic drill Info ?
发表于 2021-8-31 22:14:28 | 显示全部楼层 |阅读模式
So I have a older Black and Decker angle grinder. And i really like the grinder older model but a work horse. And i was talking to some older gentlemen and they said that they make a magnetic drill and some other tools also. And i was just wondering if any one could give me more info . And does any one body have one of these machines. ThanksMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:yea i have a couple what do you want to know about them?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I do not have a mag base drill, but I put one on my list of  "When I Win The Lottery" tools when I worked at the shipyard.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I would like to know if they take normal bits for you your basic drill.?And  also are they still available to buy. And when did they start making them like the year?  And how well does it drill holes in to  steel? ThanksMillermatic 211 with mvp plugs miller titanium series welding helmetstihl chain saws 8 ft welding table
Reply:They dont sell them anymore the ones i have are mid 80's at the newest.All my black and Decker's take annular cutters, but i have a couple of Milwaukee's that take drill bits.They started makeing them in the 50'sVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:You can still pick them up on Ebayhttp://www.ebay.com/itm/Black-Decker...item23219341a5
Reply:Sorry about the Pic, a little on the large size, forgot to resize
Reply:Ive got one just like the big picture, that I bought at the scrap yard for 5.00 It dose not have the mag base but has the atachment to hook it on. I made a steel plate for a table and use it for drilling all my big holes. It will push a 1 inch bit with no trouble. also the ring around the top is the reverse switch.  Mac
GMT+8, 2026-1-2 05:13 , Processed in 0.097767 second(s), 18 queries .
