Kalamazoo H7 Bandsaw parts ??
发表于 2021-8-31 22:14:27 | 显示全部楼层 |阅读模式
Looking for some H7 Kalamazoo band saw parts,Need a blade guide arm assembly , some were fabricated steel on the older ones from the 70's .Newer ones in the 80's were cast aluminum. Need the complete arm ,i can replace the bearings just need all components.Thought i try and find one instead of building it from scratch.
Reply:http://kalamazoobandsaw.com/
Reply:Originally Posted by bosox100My online supplier for band saw parts cater replacement parts for Kalamazoo band wheels, drive line parts, feed system and blade guides and more. This is the site:SPAM SITE.
Reply:Originally Posted by bosox100I am not spamming! The thread is about kalamazoo band saw parts and I just cited a site where they cater replacement parts for kalamazoo brand.
Reply:I can buy new , just looking for something someone has sitting around.Could even use th bearing guide setup from another brand an make my own arm.
Reply:You can also try the folks from this site: www.vintagemachinery.org. Folks there are keepers of vintage machines! Some also sell bearing guides. Good luck.
GMT+8, 2026-1-2 05:02 , Processed in 0.098992 second(s), 18 queries .
