SA-200 Governor Gasket replacement ?
发表于 2021-8-31 22:14:19 | 显示全部楼层 |阅读模式
Not by the book. The book shows one punch mark on the backside of the cam gear, and two punch marks on the governor gear. My cam gear has two punch marks on the front side of the cam gear, nothing on the backside. Seems as I've seen this before, but can't remember which machine. Has anyone else seen this? If it was by the book it would be so much easier to place the governor!  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:The punch marks are for lining up the mag should you have one. The governor doesn't care where you stick it in if there is no mag. If there is a mag then the slot on the governor has to line up with the mag.So I seat the mag, before I seat the governor in, The mag should be just about to fire #4 cylinder when the dots are lined up.Last edited by Cruizer; 08-17-2010 at 01:40 PM.
Reply:I called Bill, (Bill's Welding Equipment Repair) he told me a quick easy way to find the single punch mark on the carb side of the cam gear. The man knows his SA-200s! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:So share the quick easy way to find the punch mark. Mine was very hard to find as the punch mark was so slight I am still not sure it it is the right tooth but it seems to run OK."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Yeah they don't put a lot of effort in installing the punch mark do they? Maybe they need a bigger hammer?Bill told me to roll the engine over until the “DC” mark on the flywheel is at the pointer in the hole in the generator housing behind the air cleaner. Look in the magneto hole, at about 11-0'clock or even 11:30 the punch mark on the cam will be there! I wore the finger prints off my pointer finger cleaning the grim off the cam gear, took a magnifying glass, and there it was! Careful now the flywheel has two marks, a “T” for timing the engine, and about 1 1/4 to 1 1/2-inches from the “T” will be the “DC” mark.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:OK, already knew that one so I must be pretty close, Bill is excellent. I even took a small drill bit and enhanced mine so the next guy won't have to hunt so hard."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by kolotI even took a small drill bit and enhanced mine so the next guy won't have to hunt so hard.
GMT+8, 2026-1-2 05:02 , Processed in 0.069348 second(s), 18 queries .
