Rust cleaning solutions/acetone replacement for aluminum
发表于 2021-8-31 22:14:14 | 显示全部楼层 |阅读模式
I bought a mbc positioner that the previous owner let rust on the deck and splatter/dust gaurd is there a chemical solution that will clean this without gouging the good material and possibly remove heat tint on stainless (looking to kill 2 birds with one stone). Also what is a good cleaner for aluminum to replace acetone ? Looking for a ready to weld finish after wire brushing of course, just curious what's out there.Thanks for the advice.
Reply:Isopropyl alcohol is what most people are using now instead of acetone.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Ok I've seen some aluminum cleaner/brightener at my lws and was wondering if it is any good.
Reply:The aluminum cleaner/brighteners are not degreasers the are corrosive etching chemicals that usually contain some nasty chemicals like hydroflouric acid and they are tricky to use.
Reply:Ok I'll be picking up some of the alchohol. What about stainless heat tint?
Reply:They make pickling compounds.  They too contain hydroflouric acid but are generally easier to use as they are a paste and the exposure times aren't critical.
Reply:do you have a photo of it? can you take the deck off and machine a few thou off and have brand new metal?
Reply:Isopropyl alcohol, but make sure it is 99% (at least 93%).  There is a big difference between this and the 70%.  Your local pharmacy or supermarket should have it on the shelf, or be able to order the 99% for you.KevKevin / Machine_Punk from The Aerodrome Studio - Lincoln PowerMIG 210 MP - Meco N Midget w/custom welding station - Vintage Victor 100Current Projects: The Aerodrome Studio
Reply:As far as the positioner goes I've got it tore apart cleaned and inspected I'll prob just take a roloc disk to it being very careful, I wish but don't have the means to machine in down.
Reply:White vinegar worked for me.
Reply:Glass bead blasting removes almost no material but you have to disassemble everything.
GMT+8, 2026-1-2 05:11 , Processed in 0.098973 second(s), 18 queries .
